Navigation & Audio "Power-On" for new Amp
Old Mar 23, 2010 | 02:07 PM
GregoryK's Avatar
GregoryK
I know that there has been a lot of discussion about this.
I have a 2010 CS with the standard sound system.
Putting in a new amp speakers etc. Question is (in the non hifi system) how do you get the amp to power on with the radio. That is....when the ignition is off and you switch on the radio. There must be a wire behind the radio that switches the radio off when the ignition is off but allows the radio to be switched back on.....is there a line behind the dash somewhere? Hard to get to?
I don't want to use a switched circuit (lighter etc).
Any suggestions...Robyn...Schatzy62...feel free!
Old Mar 23, 2010 | 06:26 PM
schatzy62's Avatar
schatzy62
There isa amp turn on line on the back of the head unit and i beleive it works (turns on and off) in the base system but i am not 100% sure if that is true.
newministuff.com make a harness that is plug an play for getting the audio and some other signals out of the head unit. You would have to take the dash apart and the head unit out to put their harness in but it does make for avery neat installation.
Other than that you could find out which connector has this line in it and tap it there. I unfortunately am away from my computer for a week or more and do not have access to the wiring diagrams and i do not remember exaatly where it is.
Old Mar 24, 2010 | 06:55 PM
GregoryK's Avatar
GregoryK
Thanks for the info. I found this article a few minutes ago. You had a friend....
https://www.northamericanmotoring.co...a-circuit.html
I wonder if this circuit exists in a non Hi Fi system as there is no amp.
My guess would be that the radio must have access to a circuit that switches off when the car ignition switches off but come back on again straight away. If that is the case that wouldn't work as the amp would stay on. Maybe that is one of the circuits you mentioned in your previous post that shut off after a period.
If the car is non HiFi then why would it have an amp-on wire connected. Especially as people say the wiring is different even if the HU is the same.
Guess no one ever tested that X15 connector?
I would hate to have to take the radio out for this switch!!!
Old Mar 25, 2010 | 07:23 AM
schatzy62's Avatar
schatzy62
I think you should check the X15 connector to see if there is a wire at Pin 1 and if so does it turn on and off with the radio. If it does then you are golden to use that as the on "amp on" line.
Old Mar 25, 2010 | 09:14 AM
GregoryK's Avatar
GregoryK
Just read the manual for the amp. It's a Kenwood KAC-8404. It says that if you are using speaker level input connections that you do not require the power cord wire! The unit has "signal sensing turn-on".
Has anyone else ever heard of this? If you are using preamp inputs from your HU then you require the 'power-on' cable because they are a non amplified source so the amp can't detect them......
Old Mar 25, 2010 | 09:39 AM
schatzy62's Avatar
schatzy62
Yes, This is actually very common. But there are some drawbacks to it. If there is any noise (buss) on the audio input lines then it can cause the amp to turn on and then it may stay on. Having a dedicated power on line is the best way to go.
Old Mar 27, 2010 | 02:56 PM
Robin Casady's Avatar
Robin Casady
After trying an Add-A-Circuit tap in the F31 fuse socket, I recommend against it. It caused problems with the climate control.
I think the only safe way to do it is to tap into the Cig Lighter circuit at one of the outlets. The fuse is a 20 amp and there isn't an available Add-A-Circuit tap that will handle that much current. Most are only rated for 10 amps.
Old Mar 27, 2010 | 03:55 PM
GregoryK's Avatar
GregoryK
Robin. Aren't we talking about the amp on wire. The main power comes from the tap at the battery right? Also if I tap into the cig lighter I need the key in the ignition to listen to music right? Also I'm not sure if the amp on wire will even come into play with the my amp as it states that you do not need the amp on wire when using line level inputs.
I appreciate your advice.
Old Mar 27, 2010 | 05:22 PM
Robin Casady
Yes, that's what I thought this thread was about.
If you use an Add-A-Circuit tap in the fuse box, it holds both the fuse for the new circuit, and the fuse for the old circuit. So, to use a tap in the Cig Lighter slot, you would either have to put a 10 amp fuse on the Cig circuit, or risk overloading the tap.
Yes, I ran a 4 gauge wire to run one amp.
To have the audio play, the engine must be running. This is inconvenient, but the safest way to do it. A big amp can draw a lot of power and drain the battery. Unless you find a way to put in a more powerful battery, best to not run the audio when the engine is off.
Old Mar 30, 2010 | 05:38 AM
GregoryK's Avatar
GregoryK
I guess one of the nice things about my radio is that it has Bluetooth. When I am on a call and I stop and turn off the engine the call continues....then when I pull out the key the phone stays connected till either I push end on the radio or the other person hangs up.
The problem with using the cig lighter is that this feature will go and if you are on a call you will have to leave your engine running. Not really practical in a parking garage etc..
I'm going to put a voltmeter on the x15 today...I'll report back.
Old Mar 30, 2010 | 09:53 AM
Robin Casady
You are running a fairly powerful AB amp (smoother, but not as efficient as a D amp). I wonder how long you can talk with the engine off and still be able to start it again? People have had problems with the MINI battery going flat from normal use when they make too many short trips. You got a long commute to keep that battery charged?
Old Mar 30, 2010 | 11:44 AM
GregoryK's Avatar
GregoryK
Robin will try it out and let you know. Mostly very short trips but so far no battery probs.....
Old Mar 30, 2010 | 10:44 PM
Robin Casady
I see one of these in your future.
Old Mar 31, 2010 | 04:48 AM
GregoryK's Avatar
GregoryK
Thought I would put some extra batteries in this...just incase!
Old Mar 31, 2010 | 06:11 AM
schatzy62's Avatar
schatzy62
Old Mar 31, 2010 | 10:00 AM
GregoryK's Avatar
GregoryK
This is a little "Off Topic".. using the boost HU do I and the 4 channel amp. Do I do the channel swap and use all 4 feeds from the radio or do I just use the front unfiltered signals and split them to the front and rear channels....I would have to add an in line fader.
Thanks for any ideas.
Filmy
15
Jun 6, 2023 06:27 AM
Filmy
Apr 28, 2019 11:37 AM
Filmy
Sep 7, 2015 08:27 PM
jesterofatlas
Sep 4, 2015 11:23 PM
