Tire Pressure Monitor System (TPMS)
Old Mar 20, 2010 | 09:43 AM
MINI28741's Avatar
MINI28741
The TPMS on my 2006 MCSCa has always worked fine. The yellow TPMS indicator light came on this week. I checked the tire pressures and three tires were down 1 PSI from the original setting and the fourth was down 2 PSI. I repressurized all four tires to 40 PSI, started the engine and held the TPMS reset switch down for about 10 seconds. The indicator light will not go out. I have tried this several time and the light stays lighted. What do I check next. Any ideas? Bad switch? Software glitch?
Old Mar 20, 2010 | 07:00 PM
MintJulep's Avatar
MintJulep
Drive.
You need to drive a ways after pressing reset. The system needs to compare the rotational speed of the wheels as part of the reset sequence.
Old Mar 21, 2010 | 02:57 PM
MINI28741's Avatar
MINI28741
Originally Posted by MintJulep
Drive.
The TPMS finally did reset on the 2nd day of driving; after about a total of 40 miles. Don't think it should take this long. In the past it has reset after five miles.
Old Mar 21, 2010 | 03:20 PM
rkw's Avatar
rkw
I have a 2006 and my TPMS has always reset in a few seconds, after driving barely 100 yds. TPMS relies on the rotational (ABS) sensor which may be going bad. Mine needed to be replaced recently.
Old Apr 21, 2010 | 07:34 AM
isthar's Avatar
isthar
hey rkw: when you're saying that TPMS relies on the ABS sensor -- you realize newer TPMSes aren't that way... do you know that the 2006 TPMS is the passive, abs-based ones?
Old Apr 21, 2010 | 09:33 AM
Alex@tirerack's Avatar
Alex@tirerack
2007 forward is when the direct monitors were used!
Alex
Old Apr 21, 2010 | 01:45 PM
Robin Casady's Avatar
Robin Casady
Alex
September 2007. Early 2007 still had the rotation-based FTM system.
Old Apr 22, 2010 | 08:50 AM
Alex@tirerack
We've seen it both ways in early 2007
Alex
theblackfalcon
Oct 11, 2015 09:49 AM
TJANK
Aug 24, 2015 06:11 PM
Terry Gallentine
Aug 11, 2015 03:31 PM
nomar116
Aug 9, 2015 09:42 AM
