Is this whirring noise normal? *VID*
Old Feb 18, 2010 | 10:01 AM
plasticknives's Avatar
plasticknives
edit: was the harmonic damper rubbing. replaced, all is well.
Old Feb 21, 2010 | 02:25 AM
untdavid's Avatar
untdavid
I have that same sound...what is that noise?
Old Feb 21, 2010 | 04:48 AM
zuki650s's Avatar
zuki650s
How many miles are on your mcs? I've heard this alot on higher mileage cars, i believe it usually turns out to be the blower.
Old Feb 21, 2010 | 05:55 AM
herbie hind's Avatar
herbie hind
pull the belt and fire it up for a short bit and see if noise gone . sounds like maybe a a.c or alt. bearing.
could even be idler or tensioner so you may want to use stethescope or hose on each pulley first to try and find it . then pull belt and spin each by hand feeling for bad bearing . may even be belt alignment issue .(worn on one side)
Old Feb 21, 2010 | 07:44 AM
Some Guy's Avatar
Some Guy
Just keep in mind that if you do this you have no water pump. So Only run it for like, 30 seconds to a minute if it is cold.
lweaver
Sep 17, 2024 08:22 AM
Colt45Magnus
Aug 27, 2024 05:03 AM
Sailorlite
Sep 4, 2015 07:03 PM
Sep 4, 2015 09:23 AM
Sep 3, 2015 02:06 PM
