Electrical Garage Door Opener Mod?
Old Feb 18, 2010 | 09:28 AM
mordecai's Avatar
mordecai
I have a 2007 MCS that didn't come with any type of homelink or programmable garage door opener. I'd like to add one, possible to the center roof light fixture, or at least somewhere obscure. Right now I use the type that clips to the visor. Has anyone done this or have a suggestion of how to go about putting one...somewhere? Also, if I could get one off a newer model (08-10) from a salvage yard or spare parts department, do you think it would fit in the 07?
Thanks!
Old Feb 18, 2010 | 11:49 AM
schatzy62's Avatar
schatzy62
Physically it would probably be just a replacement but as for the wiring needed for the Homelink it is probably not in your car. That would make it rather difficult to add.
Old Feb 18, 2010 | 01:22 PM
jcauseyfd's Avatar
jcauseyfd
Personally, I'm hoping to purchase this one day...
Flash2Pass
Old Feb 18, 2010 | 01:49 PM
iwashmycar's Avatar
iwashmycar
^^ Yup me too
Old Feb 18, 2010 | 01:56 PM
r52pimp's Avatar
r52pimp
Might want to try to look at this:
http://www.motoringalliance.com/libr...nstallation-2/
It was done on a Gen 1, but the instructions should still apply. The wiring is easy. Ground and power.
Old Feb 19, 2010 | 05:28 AM
mordecai's Avatar
mordecai
Thanks guys, I knew about the flash2pass but I'm still rather unimpressed with it, I'd rather have a straight up button on the roof somewhere. I may see if I can engineer something myself, I have an open toggle switch spot where the light switches are, maybe I can find a replacement switch from a salvage yard and wire that to my opener. I'll let you know what I figure out.
Old Feb 19, 2010 | 07:06 AM
Mini2na's Avatar
Mini2na
I have velcroed a small transmitter under my arm rest. Cheap and out of sight.
Old Feb 19, 2010 | 07:36 AM
schatzy62's Avatar
schatzy62
The switches up there are not like normal switches. it it just a toggle that activates two micro switches that are built into the sub structure. You most likely will not be able to fit a toggle or other switch up there.
But thinking about it. After the cover peice has been removed there is am opening in the sub structure that would house the Alarm Motion sensor, and if you do not have the alarm that would be a place you could put the transmitter and then fashion some sort of button to press the button on the transmitter.
Old Feb 19, 2010 | 09:33 AM
rkw's Avatar
rkw
The FES Auto Sport module will let you use your Sport or DSC button via double tap. It can be connected to a garage door opener or any other accessory.
Old Feb 22, 2010 | 06:45 AM
litebrite2001's Avatar
litebrite2001
Is this about what you are looking for? This was done with a homelink visor that I picked up at a salvage yard for free (It had been taken off and was sitting in the dirt). I'm not too happy with the color difference, so I'll probably try again with another visor color. Once I find the right color, I'll do a writeup. Be warned that it involves some decent dremel skills. Splicing 2 wires shouldn't be a problem though, right?
Old Feb 22, 2010 | 09:39 AM
schatzy62's Avatar
schatzy62
litebright,
That looks awesome, well except for the color issue but if you were to find a black switch set that would look good. Or maybe try some interior paint to match the grey color. Taping the numbers may be tough but could be well work it.
Keep up the good modding work.
Old Feb 22, 2010 | 12:14 PM
mordecai's Avatar
mordecai
That is EXACTLY what I was looking for. Where did you pull the power feed from? I'll see if I can find a homelink switch somewhere around here, possibly black.
As for the numbers, maybe a stencil or something? Personally I'd just take them off, it would make for a more "sleak" look.
Thanks!!!!
Old Feb 22, 2010 | 01:02 PM
litebrite2001
If you search on here for hardwired radar detectors, or others doing a homelink mod, you can find the correct wires. It is a larger purple with blue stripe for switched +12V, and brown for ground, I believe.
edit1: I should also add that the numbers light up... green. I'll be desoldering some LEDs in the near future. I don't really need them to light up, but if I can find an orange replacement without too much effort, I'll do it. This is a work in progress as you can see. Painting the whole thing black would be the cheapest and easiest solution though.
edit2: I pulled mine down and confirmed that the +12 is the larger purple with blue stripe, and the ground is brown. Pins 5 and 6, respectively, on the black connector.
Old Feb 23, 2010 | 08:12 AM
mordecai's Avatar
mordecai
Awesome, thanks for looking that up for me. I'll see what I can come up with here and post some pics, maybe this weekend.
Old Feb 27, 2010 | 08:07 PM
kukaepe's Avatar
kukaepe
I took a very simple approach to this issue. I fastened a couple of strips of 3M double sided "foam" tape to the back side my garage door opener and stuck it upside down to the roof of the small storage area ahead of the gearshift lever. You cannot see it but it is easy to reach your hand into that box and press the button. Just as easy as reaching overhead to toggle a switch or press a button. Low cost, simple solution.
Old Mar 10, 2010 | 11:01 AM
kopov's Avatar
kopov
Do you guys think that the auto-dimming mirror with buttons for garage door will not work on my 2007? Local jank yard has one for $125 and I am think of getting it.
Old Mar 10, 2010 | 12:26 PM
schatzy62's Avatar
schatzy62
I would check to see if the wiring is in your car before purchase.
khumpert
Nov 30, 2015 11:48 AM
Shane Wendel
Electrical
Aug 20, 2015 06:50 AM
Bennyboy
Aug 18, 2015 07:28 AM
SoCalledFriend
Aug 6, 2015 06:59 AM
