Drivetrain Scangauge II, accurate?
Old Feb 8, 2010 | 06:32 PM
jirsty's Avatar
jirsty
Is this guage accurate? using the onboard computer how it does?
Please inform me more about it.
Thanks.
Old Feb 8, 2010 | 07:08 PM
Motor On's Avatar
Motor On
Thanks.
MPH was accurate, after several fill-ups the tank to empty was accurate, the MPG is within at least 1MPG. RPMs are dead on. The xguage of HP seems a little off, but it works "voodoo" as Blimey calls it, to make that calculation.
Old Feb 8, 2010 | 07:26 PM
jirsty's Avatar
jirsty
What about for boost?
Old Feb 8, 2010 | 08:42 PM
Suzanne's Chili Red S's Avatar
As long as elevation is taken into account when programming it to read boost, it is fairy accurate.
Old Feb 8, 2010 | 10:59 PM
jirsty's Avatar
jirsty
Do you own one?
Recommend?
Old Feb 8, 2010 | 11:38 PM
Mister-Aandrew's Avatar
Mister-Aandrew
i have one. programmed it to the correct elevation, and yes its fairly accurate. everything on it is really good, i love how it reads the temps, but like stated above, the HP xguage isnt all that great. But yes, id recommend it, i find it to be the best thing in our cars.
-Andrew
Old Feb 9, 2010 | 01:46 AM
jirsty's Avatar
jirsty
-Andrew
Yeah, seems like price vs function its a great deal.
Thanks for the info.
Old Feb 9, 2010 | 05:48 PM
-Andrew
+1!
Old Feb 9, 2010 | 08:43 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We were the first MINI vendor to sell the scangaugeII. We started using it a few years ago and liked it so much I started carrying it. I think it is very accurate, as long as you set it up correctly with the correct engine size, fuel tank size and you can even correct for wheel and tire size. Personally the thing I use it most for is monitoring coolant temp. You can't go wrong with one, especially with the amount of info you get for the price.
Old Feb 10, 2010 | 12:24 AM
jirsty's Avatar
jirsty
Kind of funny, the reason I actually looked into them recently and noticed that they do a whole lot of different things is because I clicked on the link in your signature and saw it haha.
Old Feb 10, 2010 | 11:38 AM
beken's Avatar
beken
You going to bring some to AMVIV and give me a special price on one installed?
Old Feb 10, 2010 | 01:21 PM
WayMotorWorks
Vendor
I'll bring some to AMVIV and give FREE install on them.
Old Feb 10, 2010 | 01:34 PM
jirsty's Avatar
jirsty
ah!
I want to go to AMVIV but hate putting miles on the MINI.
I guess I should just bite the bullet and go.
Old Feb 10, 2010 | 03:00 PM
bee1000n's Avatar
bee1000n
I assume this requires running a wire from the OBDII port up to wherever the gauge is going to sit. Are there any wireless versions?
Old Feb 10, 2010 | 05:12 PM
jirsty's Avatar
jirsty
Speaking of OBDII port,
Is that the port right under the steering wheel?
Old Feb 11, 2010 | 05:26 AM
2mD's Avatar
2mD
yes
Old Feb 11, 2010 | 09:34 AM
Mini_Crazy's Avatar
Mini_Crazy
Question Way Motor Works:
Where is the Scangauge typically mounted on a MCS w/Nav, and how are the wires (cleanly) routed to connect it?
Old Feb 16, 2010 | 10:21 AM
beken's Avatar
beken
I've seen pictures of them mounted under the toggle switches on R50/R53 MINIs. I think that's a great place for them. I believe there is also a mount available that places them beside the tachometer.
Old Feb 16, 2010 | 11:02 AM
jirsty's Avatar
jirsty
Yeah,
Thats where I want to put mine, but i already have boost gauge and a GPS there.. haha.
I think I can fit it right above one or the other.
I hope so.
Old Feb 16, 2010 | 11:36 AM
Motor On's Avatar
Motor On
Yeah,
I hope so.
Here's where I put mine, up on the top of the dash as the cubbie area was already filled.
If you search for some of the recent scangauge threads there's lots of photos/ideas for mounting.
Old Feb 17, 2010 | 04:37 PM
CARVNIT's Avatar
CARVNIT
I have posted just like above and find it very practical for keeping an eye on things. Besides it provides entertainment when you're stuck in traffic crawling and observe all the temps rise. Got mine from Way, it's been very accurate from what I can tell and easy to program. Only question I may have is how accurate the boost is.
shorenetworks
Nov 4, 2019 06:18 PM
dinomaniac
Sep 18, 2018 04:19 AM
OutMotoring
Nov 16, 2015 07:04 AM
USA-RET
Nov 9, 2015 07:27 PM
Oct 19, 2015 08:07 PM
