Clutch Squeak
Old Jan 13, 2010 | 09:15 AM
ash5's Avatar
ash5
Clutch Squeak
'09 MCS with around 5,000 miles. When I first get going, the clutch sounds fine, but around 10 minutes into my drive, it the pedal to get "squeaky." Stays that way even once the car is off, but when I get in after a long day at work, no squeak until around 10 minutes into driving again. Thoughts?
Old Jan 13, 2010 | 10:17 AM
skakid812's Avatar
skakid812
Happened to my 2010 mcs as well... I assumed it was from being brand new and you really gotta wear it in so all the moving parts are nice and broken in, might need some oil or something. My squeak is gone I'm at around 3k
Old Jan 13, 2010 | 10:20 AM
Helix13mini's Avatar
Helix13mini
Does the squeak sound like it's coming from the pedal or inside the engine bay?
Old Jan 13, 2010 | 10:53 AM
ash5's Avatar
ash5
Definitely the pedal
Old Jan 13, 2010 | 12:08 PM
skakid812's Avatar
skakid812
It goes away in time
Old Jan 23, 2010 | 06:10 PM
ellinara's Avatar
ellinara
My dealership greased the pedals and it worked for about a week and it does it again now...22000 km
Old May 23, 2010 | 10:17 PM
ash5's Avatar
ash5
So my dealer replaced quite few components and it helped for a while, but it's now doing it again in weather > around 70 degrees after about a 1/2 hour of driving. Sometimes I can reach under there and pul and push on the spring, and then things are better for a while. i think it just needs to be lubricated around the spring. Would WD40 work for this, or some other grease/lube?
Old May 23, 2010 | 11:42 PM
ellinara's Avatar
ellinara
I took my car to BMW to resolve the issue (under warranty) and they just greased the pedal (Again). After doing this a second time, the issue was finally resolved
eliseo1981
Nov 2, 2015 11:24 AM
unxpectederror
Oct 22, 2015 12:16 PM
torpeau
Oct 8, 2015 11:10 AM
Oct 1, 2015 12:13 PM
Sep 28, 2015 09:13 AM
