Interior/Exterior door speaker ring
Old Jan 6, 2010 | 12:03 PM
JamesH's Avatar
JamesH
door speaker ring
does anyboody know how to reomove the door speaker ring?
Old Jan 6, 2010 | 01:46 PM
Fatherdeth's Avatar
Fatherdeth
Are you talking about the one near the bottom? If so, the door panel has to come off. The grill is plastic welded on and has to carefully, and I mean CAREFULLY drilled out. I used epoxy to put mine back on after painting, but you can use small screws.
Old Jan 7, 2010 | 12:01 PM
wyefye's Avatar
wyefye
i found out the hard way that they were not supposed to come off... after i pried it off...
out came the jb weld.
Normal cars... yannow, they come off...
Old Jan 8, 2010 | 12:33 AM
chris.j.lamb's Avatar
chris.j.lamb
IF you pull the speaker ring off and then replace it with a brand new one it can be retained with 8 speed nuts, MINI part no. 54318246804.
This is much easier and cleaner than using any glues.
See here :-
http://www.realoem.com/bmw/partxref....r=1&series=R50
Old Jan 8, 2010 | 06:46 PM
Fatherdeth's Avatar
Fatherdeth
See here :-
I had no problem with epoxy and it was a clean install. Sparce amount is the key. If you don't wan't to use adhesives, then screws work fine. If you have ever taken your grill off or even the sidemarker lights, you know what a pain speednuts can be.
Filmy
Apr 28, 2019 11:37 AM
Filmy
Sep 7, 2015 08:27 PM
Sep 4, 2015 09:10 AM
Sep 3, 2015 10:45 AM
