Window Problem/ No suction
Old Dec 13, 2009 | 05:54 PM
melmahon's Avatar
melmahon
Hi
This is the first I have noticed because its pouring out but my drivers side window is not sealing closed when you shut the door. It doesnt suck in when the door closes whick is causing water to leak in.
When I tried to roll down the window with the toggle button and roll it back up again, the window does not stop when it is completely up. It rolls back down again which means I am not able to roll window completely up. I have to stop right before it is completely closed so it doesn't roll back down again
Would anyone know what is causing this?? I am so upset
I have a 2009 Cooper S
Thanks!
Melanie~
Old Dec 13, 2009 | 07:34 PM
RJKimbell's Avatar
RJKimbell
It's a known problem...take it in to the dealer, they will have to do a Re-Initialization and that should fix the problem.
Old Dec 14, 2009 | 04:20 AM
melmahon's Avatar
melmahon
thank you so much. I'm calling now!
Old Dec 14, 2009 | 01:16 PM
MINIDean's Avatar
MINIDean
You don't have to take it to the dealer to reinitialize. Just turn the car on and press and hold the power window button in the up position and hold it there for about 5 seconds with the door closed. This will initialize the window.
Old Dec 14, 2009 | 01:47 PM
onetigerlsu's Avatar
onetigerlsu
Back to dealer ! Mine went up and down like a yo yo ! HE He ! Had to reprogram window it took 8 hours What !
Old Dec 14, 2009 | 09:20 PM
Benibiker's Avatar
Benibiker
I just did what MiniDean said and it's been good since then...
Old Dec 15, 2009 | 04:59 AM
schatzy62's Avatar
schatzy62
Just a note for you for re-initializing the windows.
It is best to follow this set of instructions to get the most benefit, these are from MINI tech support in the UK.
1. Hold window switch in down position and after window is all the way down continue to hold for 15 seconds.
2. Release and let sit for 5 or more seconds.
3. Hold window switch in up position and after window is closed continue to hold for 15 seconds.
4. Window should now operate properly. If it does not then it is a programing error in the window control circuits and needs software to be re-installed.
Many cars will work with holding for less than 15 seconds but others may not.
Old Dec 16, 2009 | 09:06 AM
ikappedkermit's Avatar
ikappedkermit
I did the 15 down / 15 up and reset mine - was hitting the molding if not careful - now the window dips as expected...
USNAE2
16
Jun 17, 2022 07:17 AM
scfiveo
Sep 27, 2019 02:27 PM
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
rt808
Sep 25, 2015 01:59 PM
