R56 Saprk Plugs
Old Oct 24, 2009 | 06:58 AM
adam_randell's Avatar
adam_randell
Spark Plugs
Ive decided that my spark plugs needed changing, so bought some bosch super4's. i have a 10mm spark plug wrench, will this also get the standard plugs out?
Old Oct 25, 2009 | 12:36 AM
adam_randell
anyone??
Old Oct 25, 2009 | 10:17 AM
Robin Casady's Avatar
Robin Casady
Why do you think your spark plugs need changing?
IIRC, changing the spark plugs is not a simple matter.
Old Oct 25, 2009 | 10:55 AM
Porthos's Avatar
Porthos
What makes you say that?
Old Oct 25, 2009 | 11:03 AM
Robin Casady
IIRC, there is a coil over each spark plug, and I thought I read something about a special tool being required to remove the coil without braking something.
Old Oct 26, 2009 | 08:32 AM
clutchless's Avatar
clutchless
Plugs should last years, allegedly 100,000 miles. If you have a problem, get it diagnosed before replacing parts that probably are fine. If you do not know the two standard car spark plug wrench sizes, (and I bet the Mini takes the smaller but have no specs) maybe you should not be replacing your plugs. 10MM is the size for a 2 cycle leaf blower spark plug, not a car. Have you replaced spark plugs before? You have to be careful regarding the proper tightening torque, thread stripping, applying anti-seize (always a good idea) . Those Bosch plugs with 4 prongs have received very mixed reviews at other car sites. I would not use them. Get your car diagnosed first.
Old Oct 26, 2009 | 08:43 AM
slinger688's Avatar
slinger688
The coil is generally easy to remove as it is sitting on top and it is a bolt. But the spark plugs requires a deep thin wall spark plug socket because it is buried inside the hole. From experience, I can tell you to make sure you can "lock" the long extension bar properly to the socket. Otherwise, you will be spending some time trying to get socket out as well.
Old Oct 26, 2009 | 08:45 AM
slinger688's Avatar
slinger688
Which Mini is this?
I am not sure I would change the NGK iridiums out for Bosch super 4s.
Old Oct 26, 2009 | 08:52 AM
djam43's Avatar
djam43
I read that the r56 engine takes a 14mm 12point sparkplug socket to remove the plug . The coils just lift out.
Old Oct 26, 2009 | 08:59 AM
clutchless's Avatar
clutchless
http://sparkplugs.com/results_app.as...1&AAIA=1441103
Old Oct 26, 2009 | 09:04 AM
Oxybluecoop's Avatar
Oxybluecoop
Attachment 44558
Attachment 44559
Attachment 44560
Old Nov 10, 2010 | 06:39 AM
bbm's Avatar
bbm
Can anyone tell me how to remove the spark plug coils out of the way so I can replace my spark plugs?
Is it just pull it out with brute force, or is there a unlatching method before I can pull it out. I can not figure it out. I'm tempted to just yank it out outward. I have a strong hand but the last thing I want to do with it is to break anything in my Mini. Please advise.
Old Nov 10, 2010 | 06:58 AM
slinger688's Avatar
slinger688
On top of the coils, Lift the clips to remove the wire. Then pull up on the coils to remove.
Filmy
15
Jun 6, 2023 06:27 AM
eliseo1981
Sep 18, 2015 10:40 PM
Accessory Products
Sep 11, 2015 08:01 AM
Filmy
Sep 7, 2015 08:27 PM
Sep 4, 2015 03:56 PM
