R56 space saver tire for 09 MCS?
don c.
Front tire flat
As I understand it, Robin, ....during a front tire blowout - you jack up your mini from the side, raising front and back. You would then place good rear tire on the front. The spare tire, goes on the back.
A bit of a hassle, I realize. All due to larger front braking system.
After switching away from RunFlats, you could also pack a can of Fix-a-flat instead of a spare tire. Just a thought.
I carry a sealant/compressor, and a Dynaplug kit.
Careful with that Fix-a-flat, Slime, et al stuff. There is forum traffic on NAM about those injected products messing up the Tire Pressure Monitor sensor and sending unit.
(brake size is not the reason either)
risk damaging your differential, stressful on the drive train, and handling greatly affected
ltjpunk7
Sep 6, 2015 07:32 AM
col127
Aug 21, 2015 02:11 PM
Mini'mon
Aug 16, 2015 04:15 PM
