R50/53 i cleaned my UNI foam filter using the K&N cleaning kit...wrong?
Old Oct 7, 2009 | 07:13 AM
mini_macky's Avatar
mini_macky
thinking that the cleaning kit for foam filters & K&N filters are the same, i used the K&N cleaning kit on my UNI filter 2 days ago and so far i've done about 150kms since the cleaning. i followed the instructions on the K&N cleaning kit (yes, including oiling the filter)
so should i be worried screwing up the MAF sensor or anything because i used the K&N cleaning kit on a foam filter?
Old Oct 7, 2009 | 07:41 AM
Bigshot's Avatar
Bigshot
Never use the K&N stuff on a foam filter. Get a foam cleaning kit and redo it. It won't really mess up the car unless you have over-oiled it (real common problem). But it will degrade the foam.
Old Oct 7, 2009 | 07:51 AM
mini_macky's Avatar
mini_macky
degrade in what way? possible to make it chunk into pieces and getting into the engine?
Old Oct 7, 2009 | 07:52 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
More in a sense that the degraded foam will let dirt and junk into the engine.
Old Oct 7, 2009 | 08:17 AM
ALTA_Jarid's Avatar
ALTA_Jarid
UNI filters and K&N use a different cleaner AND viscosity of oil. The K&N oil is thinner and can run thru the foam filter and cause damage. Also the K&N cleaner is basically a degreaser type fluid and can degrade the foam and make it fall apart.
Old Oct 7, 2009 | 10:03 AM
mini_macky's Avatar
mini_macky
ALTA_Jarid: what kind of fluid is the cleaner for foam filters then? FWIW, i only applied the cleaner & oil to the outer surface of the UNI filter so if any physical damage was done, i hope it will be only limited to the outer portion of the filter
Old Oct 7, 2009 | 10:31 AM
ALTA_Jarid's Avatar
ALTA_Jarid
PM sent
Old Oct 7, 2009 | 07:56 PM
ED955S's Avatar
ED955S
Had tried them both, the UNI oil is thicker in viscosity and tackier (sticky) than K&N oil which makes it better in trapping dirt.
rtk90
Aug 29, 2019 09:08 AM
molala
Oct 2, 2015 01:53 PM
newowner
Sep 15, 2015 07:18 AM
MasterShaftner
Sep 4, 2015 03:52 PM
Sep 4, 2015 09:10 AM
