R50/53 SES LIGHT - P0138 Code
Old Aug 27, 2009 | 07:43 PM
MiniO's Avatar
MiniO
Hi
Brought a 2005 Cooperwith about 59,000 miles about 50 days ago. Had it checked by private mechanic and said it was a great deal but would need battery sooner then later. It was a real good price so I went for it.
Now Service Engine Light is on and I had Auto Zone do scan and code P0138 came up. Heated Oxygen Sensor Bank 001 Sensor 2.
Can a bad battery cause this? Car is running fine although mileage is not as good as I expected.
Also do you think the dealers 90 day warranty I got would cover this? It was an Acura dealer's used car department.
Many Thanks for your help!
Old Aug 29, 2009 | 10:58 PM
MiniO's Avatar
MiniO
anybody? Thanks!
Old Aug 29, 2009 | 11:07 PM
not-so-rednwhitecooper
No, a bad battery will not cause that.
Most likely a bad sensor. The other possibility is a short or a broken wire on the sensor or the harness. Check for chaffed wiring before replacing the sensor. It runs $250.
Old Sep 3, 2009 | 07:55 AM
jibeho's Avatar
jibeho
Have your dealer replace the O2 sensor, you should still be covered with a 2008
Old Sep 3, 2009 | 09:20 AM
MINI-charged's Avatar
MINI-charged
He said it was a 2005. You should read the thread here:
https://www.northamericanmotoring.com/forums/stock-problems-issues/174873-miniusa-letter-regarding-failing-o2-sensors-in-my-04-06-a.html
Just got the mail yesterday about the O2 sensors.
one73ronin
Aug 19, 2015 12:36 PM
Aug 19, 2015 09:12 AM
Powershift
Aug 16, 2015 05:14 PM
massmini03
Aug 12, 2015 11:19 AM
