R56 ABS, brake and triangle yellow warning lights at startup
Old Aug 26, 2009 | 10:54 AM
ramcell's Avatar
ramcell
the ABS, brake and a triangle with circular arrow came on in yellow at startup
no tire warning though.
message check shows ABS.
checked the brake fluid and its topped up.
any thing I can do or will a trip to the dealer be necessary?
'09 just a cooper 6000 miles
thanks folks
Old Aug 26, 2009 | 01:08 PM
RJKimbell's Avatar
RJKimbell
Don't drive it, have it Flat Bedded to your Dealer. Even though it's a Yellow Warning I'd be cautious about driving it, you never know when the Red Warning will come on.
Good Luck and let us know how things turn out!!
Old Aug 26, 2009 | 01:13 PM
drewstermalloy's Avatar
drewstermalloy
+1
It's free. And you won't have to worry about your safety.
Good luck!
Old Aug 26, 2009 | 05:42 PM
e30r56's Avatar
e30r56
Most likely an abs sensor. The mechanical parts of your brakes will function correctly, just the electronic assists won't be there. No safety issues with driving it to the dealer.
Old Aug 27, 2009 | 05:35 AM
ramcell's Avatar
ramcell
thanks folks. Driving it to the dealer on tuesday.
Old Aug 27, 2009 | 09:12 PM
Benibiker's Avatar
Benibiker
Something is amiss...
Old Oct 10, 2009 | 05:19 PM
jacksonrw's Avatar
jacksonrw
i just changed the front pads and bypassed the pad sensor by tieing the wires together and I have allthe warning lights up
so....what was it?
Old Feb 15, 2011 | 11:16 AM
davidq72's Avatar
davidq72
ABS Sensor Bad
Mine are all on as well, came on right after my warranty ended. Your ABS sensor has gone bad and it's a $2200+ repair if you are not under warranty. I am furious that my less than 4 year old car needs this amount of $ spent on it only a few thousand miles outside of the factory warranty. Am trying to take it up with MINI, but we all know how that is. Anyone have any advice?
Old Feb 15, 2011 | 01:20 PM
Finner's Avatar
Finner
David,
Good luck. Plead your case. Maybe you can get the ears of the Mini Rep for your area. But most likely in the end you will be reaching for your checkbook. Its tough when something goes bad right after warenty expires whether its the problem you are having or an A/C compressor or whatever.
Good luck!
Old Feb 15, 2011 | 01:26 PM
davidq72's Avatar
davidq72
Thanks Finner, appreciate it. Am pleading my case. But I won't be paying to fix it out my wallet, I will sell the car as is minus a few grand for someone else to deal. If MINI won't step up on this issue, I won't be buying another one of their cars. This is my 2nd one and I expect more than 50K miles out of a car before major expenses hit my wallet.
Old Apr 2, 2011 | 08:21 AM
Josue.Rodz's Avatar
Josue.Rodz
http://www.partsgeek.com/catalog/200...ed_sensor.html
if it's just your sensor that needs replacing you don't need $2200. just buy the sensor and have it installed. you need to do some research before going to the dealer to have it fixed. they only want to squeeze some money out of you. i'm having mine replaced along with some other tune ups. no big deal!!! good luck...
bneer
Jul 15, 2019 04:41 PM
one73ronin
Aug 19, 2015 12:36 PM
JamJam43087
Aug 16, 2015 02:02 PM
mini yellow-haa!
Aug 13, 2015 11:18 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
