Drivetrain Can I swap ECU's with a JCW
It does not sound right, and we may need some clarification.
When you have a lease, you can swap tires, and other after market accessories onto the car, but you will need to swap them back when you return them. That is the only "swapping of parts" that I know that is allowed on a lease, but it is your responsbility to return it as close to the shape you received it, minus traditional wear and tear.
Taking other parts off, especially something as crucial as the ECU, will likely cost you replacement parts, labor, and anything that may be damaged as a result.
HOWEVER, if you currently own a JCW and are trading that in, that is a different story, you can do what you want to that, but it is defintely going to impact trade value.
*sigh*
Why?
The ECUs are physically the same. The only thing different is the programming.
Why change a hard part when all that would be required is to reprogram the one you got?
Talk to Jan @ RMW. He can make your S as fast as if not faster than a stock JCW without changing anything physical on the car.
Why?
Its amazing my 1stgen Neon came with a DOHC and I swapped the bad motor with a 2ndgen SOHC. The DOHC computer controls the SOHC motor. I dubbed the ECU "Jesus."
Mark
Originally Posted by jayech (from mynes)
Also I can convert the Cooper DME (ECU) and EWS (Immobilizer) to a Cooper S if they want to convert their vehicle from a Cooper to a Cooper S without changing their ECU, EWS and Keys.
Jaytech
is talking about reprogramming the guts of the ECU to allow the swap. You can't just take one out and plug another one in and have it work without hacking the unit.
Matt
Matt
Your Cooper seems outta place in a stable of Porsches. Perhaps the PCA boards are too sophisticated?
if one wants to consider NAM sophisticated - what to name my MINI again....
BINGO. If you can go from MC to MCS with offsite (not at the dealer) reprogram, MCS to JCW is a walk in the park. You might even get your dealer to do it for the right price.
Two mistakes:
I don't have to. Anybody that has upgraded to JCW installed at the dealership can confirm.
You do have more posts than me, but I've been around a lot longer.
- Dealerships can upgrade to JCW software, so not a hack. There are even others who can upgrade you to JCW software if you've followed the right threads.
- If you were refering jaytech as hack, you haven't seen his work.
Originally Posted by orangecrush
Try it and call me back when you get it to work.
It's no different than a chevy. I put a blown bigblock in an S10 and I thought I could at least use the ECM I had from another GM that was identical except programmed for my engine upgrades and it wouldn't stay running longer than 30 seconds. The computer reads a prom chip and verifies that someone doesn't just change out ECMs to steal someone else's car.
Mark
Exactly my point. When you order something as simple as a JCW Stage I kit upgrade, it is VIN specific. You can't just throw it on another car.
Number of posts mean nothing. Experience does however. If you don't believe me, call up a dealer and ask them. Simple enough.
Mark
Mark
An MCS owner can go to the dealership and have a Works kit dealer-installed (OMG not factory installed!?) taking their MCS to JCW - the VIN doesn't change.
Thats all I've suggested, a retune to JCW, not a swap. But even if you did swap, it could still be reprogramed.
For your clearly superior experience, you sure have trouble reading previous posts.
It's real simple, ask Jan at RMW and see what he says. I'm sure he knows more about what is vehicle or vin specific than either of us.
Regardless, it's a moot point because no one would be stupid enough to waste time, effort and money trying to use a JCW tune when you can go to RMW and do a tune delivery twice as much as a JCW tune.
He didn't ask about swapping programs, he asked about physically taking an ECU out of a JCW and installing it into an MCS and expecting it to work. Yes, it would physically fit but no, it won't "just work".
THAT WAS THE ORIGINAL QUESTION I answered.
Mark
Try building engines with some real power(R50 head swaps and dodge neons not included
) and then we'll discuss sophistication.
No, I think YOU are the one that has trouble reading posts. The original poster asked if you could take an ECU out of a JCW and install it in an MCS.
It seems we may have been arguing over the same perspective.
Originally Posted by OXYBLUECOOP
Having owned 3 MINI's since '03 this one is far from out of place in my garage.I see you've had the the same R50 since '03 and commend you for your loyalty to the brand but I see where your coming from and understand your frustration.
Not true.........I have had the JCW software installed in my R53 at the dealer in a non JCW car. You just have to talk to the right person.....
Um...
hacking a computer doesn't mean that the person is a hack, here in Silicon Valley (and everywhere, I thought) that's slang for unathorized reverse engineering and modification of code.
But this really is a tempest in a teapot. Fact is you can't just swap ECUs without code changes, no matter who does it. Another fact is that the dealer is limited to ecu code changes that are supported by the manufacturer tools, and those that use thier own or others tools can change pretty much anything in the EEPROM.
Aftermarket people actually have more freedom than the dealers.
Another thing to keep in mind is that for the R53, the JCW kit was available as a dealer add on, long after one bought the car, so flashing up to JCW was actually a supported option. Like Rossii found, but not all dealers would do it. (frowned apon by corporate). I honestly don't know if the new ECU can be "up-revved" by the dealer because of the differences in hardware between the S and the JCW. It may or may not be possible. Also, when the Minis first came out, the dealer tools were stand alone. Eventually, the switched to a system that checks in with "the mother ship" in New Jersey or wherever, for permission to do what the tech wants it to do. Times sure are a changin!
Anyway, don't let me stop whomever wants to try. Go ahead, and let us all know what you find. nothing replaces experimental evidence!
Matt
Matt
ebowling
90
Aug 4, 2019 09:15 AM
minimofo
Apr 4, 2016 07:36 PM
