R56 TPMS sensor reusable?
Old Jul 13, 2009 | 06:58 AM
maloosheck's Avatar
maloosheck
My wife damaged one of the wheels in her '08 MCS. I am shopping for a new wheel and I am pretty sure it does not come with TPMS sensor. Is the one in the damage wheel reusable? Do I need a set of new seals or a new valve?
Old Jul 13, 2009 | 08:08 AM
STLMINI's Avatar
STLMINI
I would expect it to be unless there's some visual damage to the sensor or if the trauma to the wheel was near the sensor.
I'm not sure how one would test it.
Old Jul 13, 2009 | 08:25 AM
maloosheck's Avatar
maloosheck
It looks like it is ok, since the damage is on the other side of the wheel and the sensor still correctly sends the pressure measured.
Old Jul 13, 2009 | 08:27 AM
mini cooper mini's Avatar
mini cooper mini
What would happen if you left the sensors off?
Old Jul 13, 2009 | 08:34 AM
maloosheck's Avatar
maloosheck
Left the sensors off? You mean take them out? I guess constant TPMS error.
Old Jul 13, 2009 | 08:35 AM
mini cooper mini
Is there a way of disconnecting that too? JC
Old Jul 13, 2009 | 08:42 AM
thevelourfog's Avatar
thevelourfog
It should be fine, just bring the new wheel to a tire shop and they'll swap everything over for you. You'll likely just need the tpms rebuild kit which you need every time you switch tires.
Old Jul 13, 2009 | 10:07 AM
maloosheck's Avatar
maloosheck
Thanks. That's what I wanted to know.
Old Jul 13, 2009 | 10:52 AM
SK8BRD's Avatar
SK8BRD
If you leave the sensors off you get a constant TPMS light on and a yellow caution on start up. The yellow triangle will also show constantly.
If you want to know if the sensor from the old wheel is still working hold it near the reciever (rear of the front wheel wells, front of the rear wheel wells). If you get a red TPMS error on startup then it's working correctly and reporting low pressure. If it's yellow it's not communicating.
My adventure swapping TPMS sensors between wheels is documented here.
Old Aug 24, 2009 | 08:49 PM
toolazyforalogin's Avatar
toolazyforalogin
will this work with sensors that have been dismounted from the rims? I am putting my friends OEM sensors on my new set of wheels and I wanted to make sure they are still functional before mounting / balancing the tires and spending the $
Old Aug 25, 2009 | 06:05 PM
z06invb's Avatar
z06invb
I bought a set of take off 16 inch wheels and tires from a Cooper S for my Cooper. Owner had removed the sensors for his aftermarket wheels. I installed them without them for the time being. The triangle comes up on start with a chime and then the idiot light in the cluster flashes then the triangle goes away and the idiot light goes to steady yellow. I dont notice it when driving. I will get the sensors put in at some point but if I could find a way to disable the warning lights I would just forget about them.
Waszak
Oct 21, 2017 05:55 PM
vbmike
Oct 15, 2015 04:32 AM
renchjeep
Sep 6, 2015 01:54 PM
