Screeching noise when shifting
Old Oct 20, 2003 | 04:53 PM
efcmini's Avatar
efcmini
It seems like I went problem free for the first few months and now all of a sudden I am having all sorts of little things come up. Coincidence that I'm modding? I hope not.
Anyway, the latest...The last couple of days I've noticed a screeching type noise when I am shifting from 1st to 2nd. I've tried to pinpoint it and it seems it is while the clutch pedal is fully depressed, but it will linger a little bit after I let it all the way out. The noise is almost a metal to metal sound. It does not do it on every single shift from 1st to 2nd, but probably 7 out of 10 times. It happens most when I'm "getting on it" (higher revs at shift point), but it will also do it during a calmer shift. Any ideas out there?
I obviously have yet another trip to the dealer but I'd like to know what I'm complaining about when I ask them to fix it.
Thanks,
Ken
Old Oct 20, 2003 | 05:30 PM
Tonygba's Avatar
Tonygba
It sounds pretty similar to what we had on my 02 MCS. At about 10k miles we noticed from 0-5 mph a rubbing metal sound; somewhat like sticking brake pads. Had it in the shop for diagnosis, they heard the sound, and the dealer said we needed a new transmission; they threw a new clutch in for free (all under warranty). It had something to do with the final drive assembly? We did not get much more info than that.
I must say I am not really happy with the new tranny... It just doesn't shift the same and I think I am noticing a little bit of vibration at highway speed that was not there before.
Get yours checked out... and good luck! (we still love our MINI; but is getting to be like a problem child!)
Old Oct 21, 2003 | 07:26 AM
savage65's Avatar
savage65
Are you sure you're using the clutch?
Old Oct 21, 2003 | 08:34 AM
efcmini's Avatar
efcmini
Thanks for the feedback Tonygba. I certainly hope my problem isn't as severe as yours was.
savage65: i know you were only joking, but just so's there's no confusion, this isn't a grinding noise like you would hear if you were to shift incorrectly (grind the gears). This is almost like a glancing blow, a sliding blow, a...I don't know, but it don't sound good. It's almost like if you were to rub two sheets of metal against each other.
Ken
lweaver
Sep 17, 2024 08:22 AM
Supertractor3
Apr 7, 2017 11:16 AM
rob&JCW
Sep 10, 2015 12:06 PM
Tinklespout
16
Sep 6, 2015 11:39 AM
SneedSpeed
Sep 2, 2015 05:34 AM
