Drivetrain Stock Header Modification
Interested in modifying the stock header a bit (pre-cat or pre-cat material removed) - new neighbor with excellent welding/fabricating skills. What material is the stock header constructed from?
Some older threads discussed this "poor man's" option a while back - any updated or new information out there on this modification?
Thanks for any responses.
I recommend going further than gutting the pre-cat, this way you can clean up the primary tube ends where they are squeezed together, and remove factory weld slag. Replacing the pre-cat makes a nice smooth collector.
A jig would need to be made for the original shape to align the pieces afterwards. The above example was made at Corky Bell’s shop. Since you are close to Atlanta I would send it off to Juston Poole 404-625-1882 to have him perform the work. He takes a different approach to the tubing, but the workmanship will be top-notch.
Thanks for the responses guys - can anyone tell me what material the stock header is constructed from?
...it's some form of stainless steel, not sure which one.
I'm sure you have noticed how black the insides of your tail pipes and tips are...mine used to be like that too, until I removed the pre-cat. If I swipe my finger in the tail pipe now, there is hardly any black on it.
Originally Posted by resipsamcs
Any noticeable hp/tq gains?
Any difference in sound/drone/etc.?
Any problems?
Do you recommend this mod?
Hope that helps.
I wasn't exactly sure what kind of hardware you had in your car, so I tried to word it with some gray area.
The weld joining my pre-cat to the stock assembly snapped, so I ended up gutting out the pre-cat, rewelding the pipe back together and installed back in. Better sound and a wee bit more peppy feeling (Maybe just in my head)
Aug 7, 2015 05:55 AM
