Drivetrain ECU question (kind of technical)
Old May 31, 2009 | 07:34 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
Hi,
I have a 2003 Cooper S with a 2005 transmission. The cruise control doesn't work because the ECU expect a certain gear ratio from the 2003 transmission.
I've done my homework and found that if I get a 2005-2006 ECU, it should work.
Now, if my dealer agrees to do it, will they be able to enter my VIN number into the ECU in order to make it work?
Can they program the new ECU to have my car's option such as DSC, OBC, and (most importantly) cruise control?
Thanks a lot!!
Old May 31, 2009 | 07:45 PM
fullcollapse40's Avatar
fullcollapse40
a new DME will have to encoded for your VIN..which corresponds to an '03 R53. So basically you have a new DME with the same coding/programming as you had before.
If it is even possible to code and program a newer dme part # with the older programming, which I dont think it is.
Old May 31, 2009 | 08:00 PM
DarkMiniCooperS
thanks for the fast answer!
So basically, I guess you mean: NO... ??
Old May 31, 2009 | 08:10 PM
muladesigns1's Avatar
muladesigns1
Originally Posted by DarkMiniCooperS
Hi,
Thanks a lot!!
you may want to ask the guys at Mynes. I know they actually write there own program for the mini. If theres anything ECU related i'm sure they can help you out. they are a vendor on here and are very helpful guys.
Old Jun 1, 2009 | 06:42 AM
jbkone's Avatar
jbkone
also check the threads on moving from teh Midland's 5-spd to the 6-spd. I've read something about reprogramming, so you shouldn't need a new ECU. I have an '02 R50 and put an '03 6-spd in it. Cruise works in 4th and 6th, but not 5th. odd, but liveable. Have you tried different gears?
Old Jun 2, 2009 | 04:45 PM
DarkMiniCooperS
Thanks for the help...
jbkone, only the 3rd ger works with the cruise control... not very efficient on fuel economy at 65MPH... lol
Old Jun 2, 2009 | 07:11 PM
jbkone's Avatar
jbkone
You might chat with TxSpeedwerks (or whatever their screen name is). They're (he?) the ones who wrote the "manual" on changing to the 6-spd in the R50 and I think mentioned something about the cruise.
Quoted from their DIY guide:
"If you note that your cruise control does not work after the install, try resetting the ECU using a Peake tool - follow the instructions on resetting the CEL light to clear all codes and then give it a shot... Other things to check if the cruise doesn't work are the brake and clutch switches - ensure they are properly adjusted and functioning, and then try resetting the codes (if you have them). The codes for the clutch switch malfunction and cruise/brake switch circuit malfunctions are P0704 and P0571, respectively."
From this forum: https://www.northamericanmotoring.co...ll-how-to.html
Good luck!!
Old Jun 17, 2009 | 05:22 AM
nekit's Avatar
nekit
cruise control trans swap
I have this same problem. After doing lots of research the only person I could find that found a solution was 1fastmini. I called him and he stated that I need to find a shop that has the "autologic" programing system and they can reprogram the ECU to the values of the 2005-06 CC values. I haven't done this yet and would love to know if anyone else has. You can google autologic to get more info and find a dealer.
Hope this helps.
Old Jun 17, 2009 | 10:17 AM
jbkone's Avatar
jbkone
That's interesting. They make diagnostic tools. It's fascinating that the cruise would care what gear ratios you had. I just figured it would use velocity input to either give or take gas. it's beyone me why it matters what the tranny is. Those clever germans!
AdrenaliNate
Nov 4, 2015 07:26 PM
barnoun
Aug 27, 2015 10:08 AM
robbiedowns22
Aug 25, 2015 12:20 PM
brother i
Tires, Wheels, & Brakes
Aug 23, 2015 01:15 PM
Aug 21, 2015 11:18 AM
