Suspension Hard braking and steering judder
Old Apr 17, 2009 | 08:25 AM
M3NTAL's Avatar
M3NTAL
Is the Alta Positive Steering thing the only way to attack this?
No - my rotors aren't warped and pads are fine (brand new wilwood kit)
Even with my stock brake setup, the car would get squirly when hard on the brakes.
Old Apr 17, 2009 | 08:32 AM
onasled's Avatar
onasled
What's your suspension setup? Lowering springs on factory struts? Possible failed front struts.
M3NTAL's Avatar
M3NTAL
Cross coilovers, relatively new too.
Old Apr 17, 2009 | 08:45 AM
Partsman's Avatar
Partsman
Legion_of_Doom
Have you replaced your lower control arm bushings? New/aftermarket ones take the mush out of hard braking dramatically.
Old Apr 17, 2009 | 08:47 AM
M3NTAL's Avatar
M3NTAL
every bushing is indeed stock
Old Apr 17, 2009 | 08:58 AM
Partsman's Avatar
Partsman
Legion_of_Doom
I replaced mine with ones from Bavarian Autosport...
https://www.northamericanmotoring.co...-bushings.html
...the difference is like night and day.
Old Apr 17, 2009 | 09:30 AM
M3NTAL's Avatar
M3NTAL
Thank you for the link.
I tried hard braking on the street today - it defiantly wasn't as bad as it was on our horrible freeway that caused me to make this thread.
I think it was a combination of my alignment/suspension and the bad freeway.
Old Apr 17, 2009 | 11:09 AM
Ryephile's Avatar
Ryephile
Solid FCABs will help tons, but like onasled said, poorly setup suspension will induce instability too. Just because you have Cross coilovers doesn't mean they're setup well. You could be getting coil bind on the fronts with the stock Cross springs during hard braking. Also you could be slamming onto bumpstops during braking [assuming they're pretty short/hard stops like most short-travel coilovers.
Old Apr 17, 2009 | 02:00 PM
M3NTAL's Avatar
M3NTAL
Thank you all for your replies.
I think the FCAB's are mostly to blame here. I've felt the butt of the car getting wild too under heavy braking as well.
Old Apr 17, 2009 | 03:26 PM
Bigshot's Avatar
Bigshot
The Alta PSRS system is a huge step up from stock. A very nice alternative to the poly bushings.
woodstudio
Mar 15, 2020 08:28 AM
theblackfalcon
Oct 11, 2015 09:49 AM
Manny_cooper
Sep 10, 2015 11:09 AM
MES11
Navigation and Audio
Aug 6, 2015 08:52 AM
