Road Racing Discussion Interested in taking your MINI road racing? Find out what you need to do to get your MINI ready!
Spring Rates For Track Guys
Old Mar 17, 2009 | 08:19 PM
M3This's Avatar
M3This
Hey guys ... I know there is already a sticky on spring rates of aftermarket springs and it can be found here:
https://www.northamericanmotoring.co...ring-info.html
However after reading through a ton of threads it seems a lot of people switch the spring rates on their coilovers. For example the guys running BC Coilovers seem to switch to 6kg and 8kg set up:
https://www.northamericanmotoring.co...-feedback.html
However I couldnt tell from the thread how many of them are doing it more for daily comfort then handling.
I wanted to start a thread in here to see what spring rates those that actually track their cars are using and what set ups they found work the best. So please post up what your running.
Thanks.
Old Mar 18, 2009 | 04:06 PM
rpterson's Avatar
rpterson
I think you might not get much response from this forum as the group here that race do not like to disclose some of their secrets. But I'll dive in and reply.
Currently I'm running KW race coil-overs on my MINI. The spring rate is as follows.
Spring Rates
Front 685lb newtons 120
Rear 900lb newtons 160
You can't just change the spring rates without changing the valving.
This is the same setup that was used in the German MINI Challenge when they used the R53 MINI.
I would not use this on the street as you'll loss all of your fillings from your teeth.
I'm sure others have different set ups Higher and Lower.
There's much more to setup then just spring rates.
Hope this helps you.
Old Mar 18, 2009 | 04:24 PM
M3This's Avatar
M3This
Thanks for the response! That is a help.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
W0TM8
Dec 19, 2019 07:50 AM
jeremy_reyes94
Sep 6, 2019 07:53 AM
TrueEddie
General Discussion
Aug 24, 2015 09:31 AM
eliseo1981
Aug 6, 2015 05:00 AM
