I need to tune my Classic up
I am needing to tune my classic up for the first time and am wondering where the best place is to buy parts is, any ideas? My mini is a 1982 Austin with the 998cc engine. The plugs I have installed now are N9YC Champions and are they the best? On another topic I posted a question on where synthetic oil was a viable option for my classic, so if you have an option on that I am all ears. Any help you can give would be great.
1. From my research I'm of the opinion that synthetic is not recommended for Minis. 20-50 dino seems to e the most recommended. I guessing here but I believe an isue to remember is that the oil is also the tranny fluid so synth may not be the best there.
2. I get most of my parts from Mini Mania or Moss but you'll get other recommendations.
3. The factory recommended plug was NKG BPR6E or BOSCH WR 8D+ (according to the Haynes....do you have a Haynes or Bentley book? Get one) gap is 0.8mm
4. What tune up parts are you looking for? If points are on the list consider replacing with a Pertronix electronic set
http://www.minimania.com/web/SUBTYPE..._Inventory.cfm
www.dsnclassics.co.uk is one of my main sources
also,
www.7ent.com
www.heritagegarage.com
www.minimotors.com
www.minimania.com
www.gbcarparts.com
also,
www.7ent.com
www.minimotors.com
www.minimania.com
www.gbcarparts.com
It wouldn't be listed for a Mini if it a manufacturer makes one that would fit...
I kinda figured that. That's why I asked here before goin out. It's all good though. I found one that fits well.
If you have points, chuck them and install Pertronix ignition for worry-free driving.
As the Mini could well be the world leader in 'customizing' it is strongly suggested that if you want do anything to the ignition you first compare what you have for a distributor verses some visual data point. Over the years many different distributors have been used in the Mini- get the right parts the first time- check this list:
http://www.minimania.com/ArticleV.cfm?DisplayID=1640
for the mini stuff:
gbcarparts.com
heritagegarage.com
7ent.com
minimania.com
minispares.com
for plugs use NGK for 73 mg midget
oil 20w50 castrol
Oil filter you can p021 for 1998 Toyota Camry v6, it's a nice medium size one unlike others that are either too big or too small.
gbcarparts.com
heritagegarage.com
7ent.com
minimania.com
minispares.com
oil 20w50 castrol
Colt45Magnus
Aug 27, 2024 05:03 AM
Sep 4, 2015 02:12 PM
minicooperlover22
Northwestern Indiana MINIacs
Aug 14, 2015 03:13 PM
Aug 12, 2015 01:24 PM
