Suspension m7 coilover installation help~
Old Feb 15, 2009 | 02:01 PM
IzzyG's Avatar
IzzyG
Attempting to install the m7 coilover system myself. Got a little lost with the rears. Maybe someone can help.
According to M7's installation guide, I need to reuse the small and large bushings from the stock suspensions. Which parts are those?
Old Feb 15, 2009 | 02:20 PM
Creeve's Avatar
Creeve
I just did my H&Rs on friday. I reused parts 12 through 5.
Old Feb 15, 2009 | 02:34 PM
IzzyG's Avatar
IzzyG
Creeve: M7's coilovers must be different because they stated that I needed to reuse only a few things. Mainly bolts but part number 10 in the diagram above(with the lower and upper bushing minus the metal cylinder). I don't see any bushings anywhere. They don't point out what the bushings look like. The only part of number 10 I can see is the metal cylinder which is not reused. What are these bushings that's supposed to be part of number 10?!!?
Old Feb 15, 2009 | 03:17 PM
Oxybluecoop's Avatar
Oxybluecoop
The only bushings I recall are number 13 and number 10 attached to the top hat.
Old Feb 15, 2009 | 03:42 PM
Creeve's Avatar
Creeve
There should be a yellow piece in the middle of 10. That is a bushing.
Old Feb 15, 2009 | 04:25 PM
IzzyG's Avatar
IzzyG
Oxybluecoop: 13? That's at the bottom. What is attached to number 10? I don't recall anything being attached.
Creeve: There are a couple of yellow pieces. Which exactly? And it was on the bottom of the top hat, not the top. According to M7's installation guide, it says there's a larger and smaller bushings. All I see is the rubbery yellow thingamagick. Anyone with pictures?
Old Feb 15, 2009 | 04:42 PM
IzzyG's Avatar
IzzyG
Creeve: Oh and the yellow rubbery yellow thingamagick's- aren't they the factory rubber bump stop? Gah I'm confused.
Old Feb 15, 2009 | 05:18 PM
IzzyG's Avatar
IzzyG
Ok, a "source" informed me that there's only 1 bushing(the yellow rubbery thingamagick) and it goes between the spring hat and top hat(which is not what the installation guide stated). Anyone care to confirm?
Old Feb 15, 2009 | 05:36 PM
Oxybluecoop
The bushing is the orange/yellow object connected to the top hat(10) of the strut in the first few pages.
https://www.northamericanmotoring.co...inisprings.pdf
Old Feb 15, 2009 | 06:27 PM
IzzyG's Avatar
IzzyG
Thank you Oxy. There's definitely just one bushing, not two like the installation guide states.
Old Feb 15, 2009 | 06:29 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
It looks like one, but it should come apart in two pieces (one half on top, the other half on the bottom).
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
