Remote Stopped Working
Old Jan 27, 2009 | 10:12 PM
BriguyR56's Avatar
BriguyR56
07 Mini Cooper S with convience package
I am having problems with the remote not working. It will open the door when i use the handle button and to start the car but the remote buttons will not unlock or lock the car. Can this be reprogramed or am i S--- out of luck?
Brian
Old Jan 28, 2009 | 03:43 AM
Capt_bj's Avatar
Capt_bj
should be covered under warranty. had one of my standard fobs do this and I got a new one from the dealer. they need a little documentation to ensure they only give it to the owner but it can be done.
Old Jan 28, 2009 | 05:28 AM
corcoranwtnet's Avatar
corcoranwtnet
You may be aware of this, but each fob has a rechargeable battery inside. They suggest that you alternate usage of the fobs to ensure that the batteries stay charged. It's possible that one of your fobs, that you use frequently, is fully charged, but you inadvertantly picked up the other fob, which has discharged.
Make sure you have the same problem with both fobs before taking to dealer.
Old Jan 28, 2009 | 07:10 AM
Minidrivr's Avatar
Minidrivr
Cars with comfort access don't use a rechargeable battery. It must be replaced once in a while.
Old Jan 28, 2009 | 08:48 AM
BriguyR56's Avatar
BriguyR56
I swapped batteries from the other working remote and still no responce. I'll try putting it in the ignition for awile to charge the internal battery. I just rolled over the 36K so warrenty is now out the door. As long as it opens the door i'll use the convience button before dropping $340 for a new key. So i'am guessing there isnt a reprogramming proceedure to try to reprogram the remote??...
Thanks for the Help
Brian
Old Jan 29, 2009 | 05:33 AM
Capt_bj's Avatar
Capt_bj
maintenance vs warranty
Thanks for the Help
Brian
maintenance is 36mo/36000 miles
warranty 4 years/50,000 miles
this was warranty when I needed a new fob....
Old Jan 29, 2009 | 05:43 AM
JCR1960's Avatar
JCR1960
Thanks for the Help
Brian
Brian,
I don't have the convenience package on my MCSa but the factory warranty is 4 years/50K where the free maintenance is 3 years/36K so you should still be under the factory warranty.Therefore they should replace the faulty keyfob under the warranty.
theblackfalcon
Oct 11, 2015 09:49 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
skippermini
Aug 13, 2015 06:13 AM
tippin
Aug 5, 2015 08:43 AM
