R56 R56 project help, blacking out the chrome trim
Old Jan 13, 2009 | 12:39 AM
killasha's Avatar
killasha
so iv posted before and asked what would some people sugest if you had $500 on a mini the responses were great got alot of good feed back.. does anyone know where i can get the chrome trim blacked out is that vinyl?
Old Jan 13, 2009 | 03:12 AM
KCinBR's Avatar
KCinBR
Just did mine last week, I used plasti-dip for everything except the beltline, and I used vinyl for that. It's very cheap and if you are not happy you can remove it very easily.
plasti-dip spray is about $8 and I paid $5 for the vinyl from a local sigh shop.
the headlight rings, grill trim, gas cap cover and tailight trim can all be removed in less that 10 min.
Check out these threads in the 2nd generation section:
https://www.northamericanmotoring.co...lasti-dip.html
https://www.northamericanmotoring.co...ml#post2611727
Old Jan 13, 2009 | 11:52 AM
killasha's Avatar
killasha
thanks man that was exactly what i was looking for where can i get my hands on some plasti-dip? pep boys? auto zone?
Old Jan 13, 2009 | 12:22 PM
bhelton's Avatar
bhelton
Try Lowe's or Home Depot.
Old Jan 13, 2009 | 12:36 PM
killasha's Avatar
killasha
sounds good does anyone know where i can find the oem xenon headlamps for an r56 ? and would it be a direct hook up?
Old Jan 13, 2009 | 02:00 PM
ecupip's Avatar
ecupip
I am not sure if the xenon lamps are a sealed system meaning you can replace the whole assembly if they are it is a direct swap, if they aren't then all the wiring would have to be changed. You will pay way more than the $500 dollars (factory) to buy the lamps separately.
Old Jan 13, 2009 | 05:13 PM
bhb7654321's Avatar
bhb7654321
Ace Hardware also has Plasti Dip...Just picked some up today so I'm excited to start painting!
Old Jan 14, 2009 | 01:38 AM
killasha's Avatar
killasha
right im about to get some today to ... is it hard to open the headlight housing.. is there a how to ? i mean i know they have to be baked but what are the steps? anyone know? also im thinking of either getting some 17" tenzo m1 all black or o.z. superturismo gt's all black...the ones on the left are the O.Z. and to the right the tenzo's... what do you guys think?
Attached Thumbnails R56 project help,  blacking out the chrome trim-oz_superturisgt.jpg   R56 project help,  blacking out the chrome trim-tenzo_typemv1.jpg
Old Jan 14, 2009 | 03:06 AM
bhb7654321's Avatar
bhb7654321
Definitely go with the Tenzos, I love the look of them, but some say they are too busy
Old Jan 14, 2009 | 09:19 AM
Gilboyto's Avatar
Gilboyto
The beltline, IMO, looks SO MUCH better blacked out on cars than the chrome. Its simple to apply (I did mine in about 25 minutes). There are some tricky areas where the curves go around the car (rear and front bonnet).
I got my kit from outmotoring.com. The vinyl tape was about 12 dollars shipped and came with enough to re-do a part if I needed to.
Old Jan 14, 2009 | 09:26 AM
MoxieMini's Avatar
MoxieMini
First of all, how well does the plasti-dip hold up on those exterior parts? Second, have any of you actually removed the Plasti-Dip? If so, were there any scratches on the chrome? Was it easy to remove ALL of it? I'm thinking of going this route myself.
Old Jan 14, 2009 | 09:35 AM
killasha's Avatar
killasha
how hard is it to take off all the chrome trim? and has anyone done the door handles?
Old Jan 14, 2009 | 02:01 PM
toolazyforalogin's Avatar
toolazyforalogin
Do not joey mod your car with plasti-dip - you can use the duplicolor satin black for the same $5 and will not peel inside your light housing.
I didn't do my own door handles but watched both Lyle and Mini Service change them out to the wrapped ones. They are a *****. There are threads that can help you but make sure you know what you area getting yourself into prior to starting the job.
Don't say I didn't warn you!
Old Jan 14, 2009 | 08:05 PM
Gilboyto's Avatar
Gilboyto
I had plasti-dipped my headlight housing earlier this week. It was a bit too cold outside and didnt come out how I wanted to, so after about 3 days I peeled it off. I just started an area where you cannot see, and it literally peels right off with little effort. Chrome looks brand new still
Old Jan 14, 2009 | 09:55 PM
bhb7654321's Avatar
bhb7654321
With the plasti dip to get it smooth you just need to make sure that each coat you put on is a full coat that is completely wet. If you spray too little so that you can see the individual grains, you will probably see that on the final product.
Old Jan 14, 2009 | 11:21 PM
amazingrando's Avatar
amazingrando
Auto on Sport Button guy
I finished my blackout last summer. I did my door handles with Vinyl wrap from Lyle. They are a PAIN to do! Give yourself about 4 hours to do both! Here are some how to threads that I started, they may be of some interest to you.
Joey Mod:
https://www.northamericanmotoring.co...-to-do-it.html
Another Good Joey Mod Thread:
https://www.northamericanmotoring.co...y-mod-r56.html
Door Handles:
https://www.northamericanmotoring.co...r-handles.html
Beltline: What actually started off as joke ended up yielding some good information. However, I do NOT recommend that you use electrical tape on your beltline.
https://www.northamericanmotoring.co...ckout-kit.html
mcoopers81
Aug 19, 2015 01:42 PM
minimaximum
R55 :: Clubman Talk (2008+)
Aug 14, 2015 04:05 PM
marendt428
Aug 8, 2015 04:44 AM
WayMotorWorks
Aug 4, 2015 01:47 PM
