R50/53 Pulley stuck
Old Jan 10, 2009 | 10:31 PM
hockeyman's Avatar
hockeyman
Pulley stuck
Hey Guys,
Got the Alta 15% w/ the alta puller. We have the puller installed with everything seemingly ready to go. We put about 3-4 cranks on the puller and it gets insanely tight. About how much pressure are we talking about here? How many pounds should we be exerting to remove the pulley from the shaft?? Ideas?
Old Jan 10, 2009 | 10:38 PM
Eric_Rowland's Avatar
Eric_Rowland
If you've got the puller on tight, a sacrificial bolt in the SC shaft and it's pulling straight, tighten until the pulley comes off.
Old Jan 10, 2009 | 10:40 PM
k-huevo's Avatar
k-huevo
If you are using the pulley clamp that requires a bolt grip puller, be sure the tip on the bolt grip puller’s center extractor bolt is smaller than the pulley shaft, or it will prevent the pulley from coming off.
Old Jan 10, 2009 | 11:06 PM
hockeyman's Avatar
hockeyman
Thanks for the replies, really appreciate it. Finally got the pulley off, just took more brute strength than we thought. We are installing the new pulley now and will need to get the sacrificial bolt out of the SC shaft.
thanks again..
Old Jan 11, 2009 | 09:09 AM
konstantinos88's Avatar
konstantinos88
You're gonna love the power!!!
Old Jan 12, 2009 | 06:13 AM
chris.j.lamb's Avatar
chris.j.lamb
What size was the bolt that you put inside the end of the shaft?
Old Jan 12, 2009 | 06:43 AM
mini_racer's Avatar
mini_racer
I actually broke a Harbor Freight crow's foot puller, or rather a steering wheel puller trying to get my OEM pulley off. So yeah, they can get tend to want to stay on there. A quick trip to Sears and a craftsman puller was required to finish the job. So it took much more effort than I was expecting as well.
Old Jan 12, 2009 | 03:47 PM
FlipSmini's Avatar
FlipSmini
my online rented puller was striped, so i rented one from orileys, the tip was too big for the shaft but with a little bit of muscle, and paying for the orileys tool afterwards, the pulley came off.
Ohh i also didnt torq down the bolts correctly so now im waiting delivery of a new base because apparently 30NM is too much torq, especially when it calls for 9.8 final. opps
Old Jan 12, 2009 | 05:05 PM
hockeyman's Avatar
hockeyman
D-OH!!
Old Jan 12, 2009 | 05:10 PM
Eric_Rowland
Another Epic Fail for the "tighten it until it breaks, then back off 1/8th turn" school of thought.
Hope it all goes back together well for you.
Old Jan 12, 2009 | 05:11 PM
hockeyman's Avatar
hockeyman
HOLY CR@P! The Stealth Catback is coming now. CAN'T WAIT
Old Jan 12, 2009 | 05:12 PM
hockeyman's Avatar
hockeyman
10mm as instructed.
Old Jan 12, 2009 | 05:15 PM
hockeyman's Avatar
hockeyman
Thanks....I am really enjoying the powergain. The work was tough and Alta has it right rated at a 4 difficulty, but their tool did the job along with some of my own tools and thought. Taking the tension off the belt and the pulley off the shaft were the hardest parts. The rest is intimidating sounding, but not that bad. Admittedly tho, I was scared $hitless when the engine was 8" in the air. She buttoned back up perfectly and off went went with a gang more power. Awesome.
bahman
Feb 14, 2016 10:29 AM
Debi's Coop S
Oct 3, 2015 08:19 AM
fkrowland
Sep 30, 2015 10:30 AM
audio131
Sep 28, 2015 02:21 PM
daviday
Sep 25, 2015 01:31 AM
