HELP! cable question on install
Old Jan 4, 2009 | 11:36 AM
80Spitfire's Avatar
80Spitfire
I was in the process of replacing the battery for my 2003 Cooper and am not sure where a cable/connector goes. The cable in question comes from the DME control module. There are two big connectors on either side but then theres a small connector coming from the cable on the top connector closest to the fire wall. It was across the hold down strap and must of come loose when I removed the hold down. I see no place for it to connect to. Any help would be appreciated. It's a ten minute job to replace the battery but I'm spending an hours trying to figure out where this connector goes!
Old Jan 6, 2009 | 06:29 PM
80Spitfire's Avatar
80Spitfire
I called a MINI Tech and aked about this clip. He said it's used as a battery cut off switch when the car is being delivered. Once delivered it's not connected to anything so just ignore it. I hope this helps someone else who had the same question as me!
Alkaidovich
Jan 30, 2021 01:35 AM
silence2-38554
Nov 12, 2015 09:39 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Super Coop
Aug 17, 2015 05:09 PM
