Suspension m7 STB
Old Dec 28, 2008 | 03:40 PM
hurleyf's Avatar
hurleyf
m7 STB
Question on installing the m7 STB. I know , I know there are a thousand entries on these but I have yet to find what I want to know and I'm tired of reading. Just want to put this on the Mini. Should the tower plates, in a perfect world, sit absolutely flat? Is it OK if they have a slight wobble to them? I assume this would mean some mushrooming already? Is it OK to go ahead and torque them down?
Old Dec 28, 2008 | 03:42 PM
gnatster's Avatar
gnatster
You would better served by fixing the mushrooming first. The torque setting for the nuts is not that high, 22 fl/lbs IIRC, and using them to try and pull the metal back into shape might lead to other issues, like snapping a stud.
Old Dec 28, 2008 | 03:46 PM
hurleyf's Avatar
hurleyf
Thanks. Got a quick and easy fix for this? I assume by your answer that they should sit perfectly flat?
Old Dec 28, 2008 | 03:58 PM
onasled's Avatar
onasled
They should not wobble at all. Just takes a hammer and some semi soft blows to get it back to shape.
Lay your plates on and find the hight spots, take it off and tap them down, and repeat untill there is no more wiggle.
Old Dec 28, 2008 | 06:25 PM
hurleyf's Avatar
hurleyf
Thanks a bunch. I'll give it a go.
devicemanager
Jun 17, 2016 06:18 PM
MJohnson81
Suspension
11
Jun 12, 2008 01:20 AM
turboexempt
Suspension
Feb 26, 2008 10:41 PM
turboexempt
Cooper (non S)
Feb 25, 2008 11:46 AM
AntiqueCarNut
Oct 4, 2006 07:49 PM
