R56 Will 18s work
Old Dec 16, 2008 | 01:55 PM
MiniLove247's Avatar
MiniLove247
Will 18s work
i have an 09 and found some nice rims, the only thing is they only come in 18". will these fit ok if i lower the car 1.4" (and is that a low enough drop, i kinda want it to be low enough so the rims would look nice) i would like to see some pics and let me know how much lower the springs are.
Old Dec 16, 2008 | 02:04 PM
inimini2007's Avatar
inimini2007
You don't live in NYC!
Uneven pavement & Pot-holes will eat you up here.
Old Dec 16, 2008 | 02:17 PM
TheBigNewt's Avatar
TheBigNewt
The rim size won't really matter because the tire will make up for it meaning that the diameter of the tire+rim is the same not matter what the wheel size. 1.4" drop is PLENTY. Like they said above don't be speeding over and bumps with that setup!
Old Dec 16, 2008 | 02:35 PM
Oxybluecoop's Avatar
Oxybluecoop
18's will be fine with a drop of 1.4
Old Dec 16, 2008 | 03:59 PM
sk8erguyzach's Avatar
sk8erguyzach
sorry to go off topic but will you need to get aftermrket control arms when dropping it that much ? im wanting to do this also
Old Dec 16, 2008 | 04:01 PM
MiniLove247
im hoping to get use /35 and what tires and drop are on that blue mini ^^^
Old Dec 16, 2008 | 04:51 PM
Robin Casady's Avatar
Robin Casady
You need to check the width of the rims, their offset, and lug pattern to be sure they will work on your MINI. The Tires, Wheels, & Brakes forum get this kind of question regularly. Check there and you should find the right specs for people using 18 wheels on a lowered R56.
Old Dec 16, 2008 | 05:29 PM
Oxybluecoop
Tires are 205/40/18.Drop is on H&R Coilovers
Old Dec 16, 2008 | 05:51 PM
MiniLove247
thats exactly what im going to do your car looks great
do you have any rubbing issues?
Old Dec 16, 2008 | 05:56 PM
MiniLove247
i was thinking just the h&r springs, do you have any idea about how much you lowerd your car
Old Dec 16, 2008 | 11:18 PM
sk8erguyzach
do you have control arms.Did lowering it affect your. Camber?
Old Dec 17, 2008 | 08:45 AM
JDR's Avatar
JDR
You don't need control arms for that small of a drop.
Old Dec 17, 2008 | 10:54 AM
Browser_23's Avatar
Browser_23
Just a comment. You pink font color is very hard to read.
Old Dec 17, 2008 | 12:32 PM
MiniLove247
the rims im going to use are 18X7 with an offset of 41. im going to use H&R lowring springs (1.4" drop) are the any problems or rubbing or will i be fine?
Old Dec 17, 2008 | 03:51 PM
sk8erguyzach
droping it an inch and a half wont affect the camber?
Old Dec 17, 2008 | 05:17 PM
Oxybluecoop
No rubbing issues with current setup.
Old Dec 17, 2008 | 05:19 PM
Oxybluecoop
I'm at about 1.50 front and 1.75 rear which evens the height out at 34" ground to bottom of wheel arch on all four corners.
Old Dec 17, 2008 | 05:22 PM
Oxybluecoop
Dropping your MINI any amount will increase camber.
Old Dec 17, 2008 | 05:23 PM
Oxybluecoop
No I have the stock control arms and don't have any uneven tire wear.
Old Dec 17, 2008 | 10:37 PM
sk8erguyzach
so it doesnt increase the camber enough to cause uneven wear.?
Old Dec 18, 2008 | 05:26 AM
DasMINI
a drop that low will not cause too much camber. i have a miata and it has -2deg of camber and the tires are wareing fine. youll probebly have less than that so you should be fine
Old Dec 18, 2008 | 06:01 AM
Red Bull's Avatar
Red Bull
I have the H&R and almost dropped 2" and no issues no changing of any parts and BMW did a 4 wheel alignment
Old Dec 18, 2008 | 07:09 AM
MiniLove247
WOW nice ride, very clean i dont have enough for coilovers now so the sprngs will have to do but if it can look like the 2 cars posted ill be in good shape.
Old Dec 18, 2008 | 01:51 PM
sk8erguyzach
kool so ill be join the lowriders club here in a couple of weeks
H&R spring
thanks for all the help guys and gals
ebowling
90
Aug 4, 2019 09:15 AM
triple5soul
21
Jul 29, 2016 04:27 AM
Getrieben
Aug 15, 2015 09:09 PM
minipopkart
Aug 13, 2015 05:22 AM
joelcseymour
Aug 7, 2015 12:43 PM
