Warning indicator light help
Old Dec 12, 2008 | 10:03 PM
bakerjam's Avatar
bakerjam
I can't find what this combination of warning indicator lights mean in the manual. Comes on when I'm driving a little aggressively, but nothing too crazy, and stays on for about 5 mins or so and then shuts off. Anyone?
Old Dec 12, 2008 | 11:10 PM
lovethecorners's Avatar
lovethecorners
Red: Car believes brake fluid is low
Yellow: Hill-assist problem
otherwise: Brake pads worn
Page 120 of the 2007 manual I believe, although this is assuming the US 2007 manual and the Canadian may be different.
Old Dec 13, 2008 | 11:55 AM
joey1320's Avatar
joey1320
top off your brake fluid and you are good to go
for some reason the level switch on the r55/56 is located kinda high on the reservoir, so even tho your fluid is ok, when you take left turns and the fluid transfers to the right, the switch picks it up as low fluid.
Old Dec 13, 2008 | 10:15 PM
lovethecorners
Good to know. Thanks joey1320!
Old Dec 16, 2008 | 09:01 AM
bakerjam's Avatar
bakerjam
Thanks joey1320!
So seeing as that I have to try this, what brake fluid do you guys recommend?
Old Jan 12, 2009 | 07:20 AM
at7815's Avatar
at7815
I too have the exact same issue. The warning lights come on when I'm leaving the garage at work and there's a bit of an incline. Which type of brake fluid did you end up getting as I need to do this asap. It's quite annoying.
Old Jan 12, 2009 | 08:58 PM
bakerjam's Avatar
bakerjam
It's still annoying me (aka I have yet to top up the brake fluid), but I would also like to know what brake fluid to use.
Old Jan 13, 2009 | 07:58 AM
corcoranwtnet's Avatar
corcoranwtnet
Check your owner's manual or talk to the parts desk at your dealer.
Old Jan 13, 2009 | 09:05 PM
guidmini's Avatar
guidmini
factory approved DOT 4 or higher
Old Jan 26, 2009 | 06:01 PM
e30r56's Avatar
e30r56
Do you get the dsc light with an ! after it in the display too? I'm getting the same assortment of lights coming on with more frequency. It started happening only when I stopped to reverse into my parking spot @ work, and until recently, it only happened at that time, and not even when I tried to replicate the maneuver elsewhere. They recently started coming on just while i'm driving, and then go off w/in a minute.
Do you guys still think it's just the brake fluid? Mine seems pretty full still.
Old Feb 1, 2009 | 06:39 AM
e30r56's Avatar
e30r56
An update to mine: Preliminary thoughts are a faulty wheel speed sensor, which they won't have til tuesday. We will see if that fixes the problem.
Old Feb 1, 2009 | 08:01 PM
bakerjam's Avatar
bakerjam
Keep me posted. Mine comes on all the time.
missinmyjeep
Aug 22, 2015 07:13 PM
I_drive_slow
Aug 18, 2015 10:47 AM
JamJam43087
Aug 16, 2015 02:02 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
