Suspension JCW GP suspension???
Old Nov 19, 2008 | 12:40 PM
Luys's Avatar
Luys
Hi NAM members,
Before 3 days ago I went to a tuning shop and I found there a set of GP JCW suspension with 3100 miles. Can I install this suspension on my car MCS 06 without any problem? as I know JCW suspension is made especially for different VIN duo to wight.
Thanks.
Old Nov 19, 2008 | 03:28 PM
GBMINI's Avatar
GBMINI
It should install with no problem; it might not be quite as good as on a GP.
If you have a sunroof, that might be a worse issue.
Old Nov 19, 2008 | 04:36 PM
tazio's Avatar
tazio
The sunroof imapct is really overrated, imo. I think the consensus is that the SR adds about 50lbs to the total weight of the car. The differences between driver weights are often greater than that of a sunroof. GBMINI (the man), for example, is not exactly... svelte, while you may be quite slim. I would snap it up if the price is right and you are looking for a good handling suspension and are not looking to lower your car much. I enjoyed my JCW suspension immensely for nearly 90k miles and never regreted the swap.
Old Nov 19, 2008 | 09:20 PM
Ryephile's Avatar
Ryephile
Do the aluminum trailing arms on the GP have the same cone insert requirements as the R56 aluminum trailing arms? If so, you'll need to cut off the built-in insert on the GP rear damper bottom mount to fit the GP damper to your steel trailing arm and have the correct damper alignment. Just something to keep an eye out for.
Old Nov 20, 2008 | 09:26 AM
Luys's Avatar
Luys
I have sunroof. I found the GP JCW suspension set for $600.
Old Nov 20, 2008 | 10:20 AM
thulchatt's Avatar
thulchatt
Buy it.
Old Nov 20, 2008 | 10:31 PM
Luys's Avatar
Luys
From which side it might not be quite as good as on a GP? it will be more stiff etc.
Old Nov 21, 2008 | 07:23 AM
Edge's Avatar
Edge
AdMINIstrator
It will probably be a little less stiff than if you bought the actual JCW suspension for your MINI, since GPs weigh a bit less.
Old Nov 21, 2008 | 04:49 PM
tazio's Avatar
tazio
But again, on a 2600lb car, the differences we are talking about are just noise. I think Ryephile's point on the rear damper compatibility is the most important thing to consider.
Old Nov 22, 2008 | 03:46 PM
quikmni's Avatar
quikmni
I beleive the GP springs might be the stiffest available. The GPs have the yellow stripe springs if that helps determine which JCW springs they are.
Old Nov 24, 2008 | 08:10 AM
nickbmw's Avatar
nickbmw
The sunroof option adds about 50kg in overall weight, so it is not exactly underrated... It is like having a passenger in the car.
Old Nov 24, 2008 | 08:13 AM
nickbmw's Avatar
nickbmw
The GP suspension would be ideal for a Cooper R50, since it is very close to the GP weight. (actually a bit lighter)
Old Nov 24, 2008 | 08:21 AM
Blainestang's Avatar
Blainestang
Originally Posted by nickbmw
The sunroof option adds about 50kg in overall weight, so it is not exactly underrated... It is like having a passenger on top of the car.
Fixed
Old Nov 24, 2008 | 08:40 AM
nickbmw's Avatar
nickbmw
Originally Posted by Blainestang
Fixed
English is no my native language Very true what u said. You reminded me of the mighty E46 M3 CSL
Old Nov 24, 2008 | 08:45 AM
Blainestang
Your English was fine... my response was simply joking that the weight of the sunroof is added to the top of the car
Old Nov 24, 2008 | 12:17 PM
amg6975's Avatar
amg6975
I dare any of you to do a blind drive test and tell the difference between a car with and a car without a sunroof.
Old Nov 24, 2008 | 01:27 PM
GBMINI's Avatar
GBMINI
Head room
Old Nov 24, 2008 | 01:39 PM
Blainestang
I generally feel like I can tell the difference in acceleration when there is a passenger in my ~260hp ~3000lb Mustang, so a difference of 100lb+ in a ~118hp ~2500lb MINI, I *might* be able to tell the difference, because the low horsepower and light weight magnify the percentage difference in acceleration seen by any given amount of weight.
For instance, add 100lb to a 2hp 200lb GoKart... then add 100lb to a 6000lb Supercharged H2.
I think the 100lb added to the GoKart will be more noticeable!
Then again, maybe I *think* I feel the difference in my Mustang because I know someone is in the car with me.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
sabjcw
Aug 14, 2015 07:40 AM
nomar116
Aug 10, 2015 11:24 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
