Drivetrain LOSS of power from exhaust?
Old Nov 11, 2008 | 08:50 PM
discodan's Avatar
discodan
how much, if any, power loss should i expect if i have a crack on a weld in the y pipe in my cat back? think i may just get a new exhaust since i bought this Invidia used and that makes it 4 years old already. i like the idea of the one-sided ones like Alta and Ireland kits.
Old Nov 11, 2008 | 09:54 PM
Mini_Joe's Avatar
Mini_Joe
Hey Disco...
We might all find out very shortly... since OctaneGuy found a crack in his Invidia resonator also... and had it replaced with a Borla resonator instead!
He says it feels like it has more power... and will probably see the dyno again soon!
Not sure which thread it's in... but it's a recent post of his.
Old Nov 13, 2008 | 11:11 PM
discodan's Avatar
discodan
thanks! i did not know that about OctaneGuy's resonator. i'm gonna search it out now. im gonna keep an eye on that.
Old Nov 14, 2008 | 08:05 AM
Bahamabart's Avatar
Bahamabart
why not just get it repaired?
Old Nov 15, 2008 | 03:40 PM
mini_racer's Avatar
mini_racer
lowering back pressure does not equal power loss
I would think that unless there is a leak in the header section where you want a more controlled flow and interaction from cylinder to cylinder, that a small leak rearward of that will not have much of an effect on power levels.
If anything, if the leak is severe enough it could lower back pressure resulting in slightly more power, but not less.
Theoretically, all aftermarket exhaust systems release power by lowering back pressure. An exhaust leak is the least path of resistance, hence lowering back pressure even more. So, an exhaust leak cannot cause a power loss. I am sure it could result in a crap sounding exhaust system, but not power loss.
Old Nov 16, 2008 | 10:43 AM
discodan's Avatar
discodan
because when i was at Helix last summer, Eric saw that one of my rear hangers was broken off and the tips were hanging crooked. Eric welded it back on but did not do such a good job (not blaming him btw, he did me a favor). When he welded it back on he welded it too far back from where it should have been and the stress is what probably caused the crack. so says the muffler shop anyway. so, my exhaust has other problems, and i would like to try something else being that i did get this one used on the cheap.
Old Nov 17, 2008 | 02:41 PM
Myke@RPI's Avatar
Myke@RPI
how much for the used cracked invidia? do you have pics of the crack?
Old Nov 17, 2008 | 02:42 PM
Myke@RPI's Avatar
Myke@RPI
Actually with the leak there is a loss of gas velocity whih lowers hp as the engine cant breathe as well...
Old Nov 17, 2008 | 03:20 PM
discodan's Avatar
discodan
if i end up getting the Alta like i want, i'll let you know when i get the Invidia taken off. probably like $200 or so to cover my installation and shpping?
Old Nov 17, 2008 | 03:22 PM
Myke@RPI's Avatar
Myke@RPI
yeah, let me know... i just need to know where the crack is from pics...
Old Nov 17, 2008 | 04:50 PM
discodan's Avatar
discodan
i'll try and get pics sometime this week. it's right in the "y" where the pipe splits into the two rear mufflers.
Old Nov 18, 2008 | 02:57 PM
minicoopersgirl's Avatar
minicoopersgirl
Coordinator :: South East - Florida
I have an exhaust leak on my 02 MCS and was wondering if this has happened to anyone else. I haven't had it looked at by a shop yet, but was hoping to just get a quick fix. My car sounds like crap and the fuel intake is definitely different!!
theblackfalcon
Oct 11, 2015 09:49 AM
Aug 21, 2015 11:25 AM
F16poopflinger
Aug 18, 2015 11:25 AM
Aug 12, 2015 01:24 PM
