Drivetrain light weight battery!
Old Nov 12, 2008 | 11:15 AM
pappasp's Avatar
pappasp
after a search i decide to change my oem battery with a lightweight!has anyone change the stock?i want to know if someone change it and what problems faced?
here is a link with the bat i want to buy!the weight of the new bat is 6.6lbs!
Old Nov 16, 2008 | 04:42 PM
UKSUV's Avatar
UKSUV
Too light and not enough cranking amps Im sure. I used to run the 11lb. Deka but it died on me...
Old Nov 16, 2008 | 07:38 PM
minimarks's Avatar
minimarks
I have the 11 pound Braille and it works great for trips, track days and twisties but I put back in the OEM battery for normal use as I don't think the capacity is enough for the normal weekly grind with maybe long periods where the battery is not being charged. My 2 pennies.
Old Nov 16, 2008 | 08:15 PM
UKSUV's Avatar
UKSUV
From what I has witnessed first hand is that once the 11lb'ers are drained they are like a miracle to revive. I ran mine for 5 months as a daily until I left my interior light on. I will be switching back to one pretty soon,,,
Old Nov 16, 2008 | 09:14 PM
minimarks's Avatar
minimarks
That's why I switch them out and I give the Braille a little charge in between uses. Even when a car is turned off there is electricity being drawn from the battery.
Old Nov 17, 2008 | 04:05 AM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
I haven't had my 11lb Braille for that long, but it is working just fine so far. My particular battery tested at well over 500A cranking, and it hasn't shown any problems starting the car in colder (but not freezing) weather.
Old Nov 17, 2008 | 04:25 AM
pappasp's Avatar
pappasp
i am resdy to buy the 6.6lbs braille battery!i care about weight!anyone who use this?
Old Nov 17, 2008 | 05:01 AM
nascar mini's Avatar
nascar mini
I have used the ''Rock'' 1228 with no problems,it has a CCA of 450 and weighs 18lbs,cost around $175.00.www.rockracingbattery.com
Bill
Old Nov 18, 2008 | 09:58 AM
sam_a156's Avatar
sam_a156
I have also had this installed for 6+ months:
BR-B14115C, Desc: Braille Carbon Fiber Lightweight Battery
It works fine, even in daily use. However some caution is required:
- if you leave the car standing for over a week, better not leave the alarm system connected...
- forget about leaving your car with the emergency blinkers on when the engine is not running
Now that it is getting colder here in Central Europe, planning to swap the OEM back on for the winter.
So, it works in daily use, but not without some compromises.
Cheers,
Sam
Old Nov 18, 2008 | 06:00 PM
UKSUV's Avatar
UKSUV
Bill
EEEEK.....my Deka was 60 bucks. I could go through a bunch for that much AND it weighs 7lbs less...
Old Nov 18, 2008 | 06:05 PM
Jtrem's Avatar
Jtrem
Damn Justin your alive? Did you hear I sold my mini for a big truck ? haha
Old Nov 18, 2008 | 06:17 PM
UKSUV's Avatar
UKSUV
Holy crap man.....I thought you dropped off the earth like I have. PM me ur number again. My box was dirty and I had to clean it.. Your such a traitor. A truck??? I thought you would have got something cooler. Like a Subie or something. If I can survive the abortion in my garage...u can do the same..
Rennfahrer555
General Discussion
38
Nov 1, 2022 03:04 PM
Teh
Jun 13, 2018 02:59 PM
eatsleepautox
Oct 30, 2015 06:46 AM
scottrn
Aug 22, 2015 07:26 PM
nismo4life
Aug 5, 2015 08:31 AM
