Suspension 15mm spacers & M7 coilvers
Old Nov 5, 2008 | 08:58 AM
Dead Ringer's Avatar
Dead Ringer
is it possible or will I rub? Currently I have the stock 17" w/ runflats, I will probably switch out the stock rims for some ultra light rims but will most likely keep the same dimensions as the current 17"ers. Will I run into rubbing issues if I add spacers?
Old Nov 5, 2008 | 09:28 AM
MiniBAH's Avatar
MiniBAH
That's precisely my setup - M7s with 15mm H&R spacers, although my rims are 18s with wider tires. No rubbing issues whatsoever.
Old Nov 5, 2008 | 09:31 AM
Dead Ringer
where did you purchase them from, or where would you recommend?
Old Nov 5, 2008 | 11:32 AM
ghosthound's Avatar
ghosthound
how wide are your tires? 215?
im looking to get some wheel spacers as well
Old Nov 5, 2008 | 11:32 PM
MiniBAH's Avatar
MiniBAH
Got 'em from Moss, and my tires are 215/40ZR-18.
I recommend
Old Nov 6, 2008 | 12:28 AM
glnr13's Avatar
glnr13
a few other things one also should consider when getting spacers:
1) offset of your wheel
2) lug bolt length
3) hub size
Old Nov 6, 2008 | 05:44 AM
MiniBAH's Avatar
MiniBAH
I got mine with the necessary longer bolts, so make sure you order those too
Old Nov 6, 2008 | 07:03 AM
Dead Ringer
thanks!! I went to the website and saw that message. Glad you confirmed this info for me!
Old Nov 7, 2008 | 06:10 PM
ghosthound's Avatar
ghosthound
how bout hubcentric rings?
Old Nov 7, 2008 | 06:12 PM
ghosthound's Avatar
ghosthound
as for the moss mini spacers... the $94 is for a set of 4 spacers correct?
Old Nov 9, 2008 | 08:51 AM
MiniBAH's Avatar
MiniBAH
Each set contains 2 spacers, and for the wider spacers they come with the ring so you can mount the wheel.
YaTuSabe
Aug 23, 2018 11:41 AM
theblackfalcon
Oct 19, 2015 05:22 AM
GAT
Oct 4, 2015 07:27 PM
Zew2888
Sep 29, 2015 08:49 PM
Manny_cooper
Sep 9, 2015 05:17 PM
