Help with radio shut off!
Old Nov 2, 2008 | 03:12 PM
MerchoMini's Avatar
MerchoMini
Today I was installing a bazooka tube ( ) into the mini cooper S and my friend was helping. We got it all wired in and running and ran the remote lead to the F27 15 amp fuse which has the radio symbol. When the car turned off how ever it did not turn the amp on the sub off. So he switched it to F10, the 5 amp fuse tried to see if it worked and now the radio wont turn on at all. I unhooked the battery to see if that would reset the system with no luck. Any one have an idea as to what could of caused this and/or how to remedy it? Thanks
Old Nov 2, 2008 | 03:35 PM
GBMINI's Avatar
GBMINI
You need to use the antenna output from the radio, to turn the amp on/off (pin 15 I think)
If the radio isn't turning on now, sounds like you blew a fuse.
Old Nov 2, 2008 | 03:40 PM
MerchoMini's Avatar
MerchoMini
i thought i blew a fuse as well but i checked both of those two fuses i mentioned and neither were blown? could i have tripped a security switch or ne thing like that?
Old Nov 2, 2008 | 03:49 PM
GBMINI's Avatar
GBMINI
No.
The radio has two supplies, one is permanent and one turns on/off with ignition.
Even with ignition off, you can press the volume **** to turn the radio on - can you do this?
Even if the security is triggered (damaged Kbus wiring), the radio will come on, and display a message.
Old Nov 2, 2008 | 03:54 PM
MerchoMini's Avatar
MerchoMini
The radio dosent light up or turn on or make sound at all. Im gonna check the fuses again maybe replace them any way but as of now i cant find a problem.
Old Nov 2, 2008 | 06:17 PM
MerchoMini's Avatar
MerchoMini
wow really weird. My buddy who is pretty knowledgable in audio and electronics came to mess with it and fixed it. He took the fuse out and turned it upside down and it fixed it. Flipped it back around again to see if itd work and again it did not. He nor i had ever heard or seen this, just a weird quirk i guess.
bahman
Feb 14, 2016 10:29 AM
pglgp1292
Oct 5, 2015 06:47 PM
simo711
Oct 1, 2015 05:36 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
