R50/53 So I replaced my torn motor mount, now what?!?!
Old Oct 6, 2008 | 05:53 PM
Mr. Incredible's Avatar
Mr. Incredible
My passenger side mount mount was completely torn and clunking HORRIBLY over rough roads, bumps, etc. I finally got around to replacing it today and took her for a test drive and its definitely better, but there is still something clunking on the right side. I can't tell if its the front or back, but what else could be doing this? Its only happening if i go over a speed bump or water run off at an angle but not straight on. Possibly the end links? Its driving me nuts!
Old Oct 6, 2008 | 08:00 PM
AutoXCooper.com's Avatar
AutoXCooper.com
How many miles are on the MINI?
Old Oct 6, 2008 | 09:16 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Put the car up on jack stands and check all bolts in the front suspension.
One thing that crosses my mind is that while the main motor mount was damaged, the engine flopped around enough to tear the lower mount's rubber.
Old Oct 6, 2008 | 09:43 PM
Mr. Incredible
It has about 33k on it. The strut mounts and control arm bushings have also been replaced.
Old Oct 7, 2008 | 10:36 AM
healey67's Avatar
healey67
With the car parked, roll down your window and push on the car side to side. (lowering window helps to push on roof). Have someone else listening under the hood or actually touching the sway bar to feel the clunking if its coming from there.
Old Oct 8, 2008 | 11:37 AM
Mr. Incredible
i have tried rocking it back and forth and don't feel any clunking. I hear some squeaks in the back suspension. I'm pretty confident that the clunking is coming from the front right.
Old Nov 26, 2008 | 07:53 AM
Mr. Incredible
i'm bringing this baby back from the dead. So today while driving to work, I jerked the wheel to the left to avoid a pot hole and felt the clunk. I can replicate the clunking whenever I jerk the wheel sharply to the left... any ideas? I have also confirmed that it is coming from the front right side of the car.
Old Nov 26, 2008 | 08:03 AM
AutoXCooper.com
that's easy, stop jerking the wheel. Sorry just couldn't pass that up.
Really, check the ball joints and the end links. I'd leave the MINI on the ground with the E-brake set, gear box in neutral and see if there is any play in the control arm.
Old May 6, 2009 | 05:34 PM
Mr. Incredible
I thought I would update this since I found the problem...
Seems that the tie rod has some play in the steering rack, go figure.
silence2-38554
Nov 12, 2015 09:39 AM
tr3y003
Oct 22, 2015 10:48 AM
JPMontes3
Aug 23, 2015 01:26 AM
sabjcw
Aug 14, 2015 07:40 AM
minipopkart
Aug 13, 2015 05:22 AM
