It can install injectors JCW in "MINI One 08/2005"?
You are probably asking on the wrong site, as the Mini One was not imported to the US. Try asking the question at http://www.mini2.com/forum/ in the UK.
Lots of luck - probably a complete waste of money.
Again - you are asking the wrong group - try MINI2, where they actually sell the One.
Well, the MINI one is the same as the non-S, just a different ecu and slight other changes. If you are asking about the jcw injectors from the S...then it is complete overkill. If you want bigger injectors, then you would likely be better off going with stock S ones. I don't know if/how much bigger they are, but they can handle much more fuel than our cars are capable of putting out. They are cheaper and still total overkill. Check the market place periodically and maybe put a want to buy stock S injectors...you will save a lot of money and still get what you want.
What you have to understand is that you will not be pumping any more fuel with the JCW injectors. You will only increase the amount of fuel that they are capable of flowing. You will still be flowing the same amount of fuel...just with bigger injectors. It will have literally no effect on anything. You may want to have a dyno tuner check the duty cycle of your injectors...I don't know if it can even be done on a mini...
If you are flowing more fuel than your injectors can handle, then you are in danger of leaning out up top and blowing up your engine. If you are no where near the top of the duty cycle of your injectors, then you are just throwing money into the trash can.
Thanks for its explanation
JCW injectors won't give you more horse power. For that you probably want to look into getting a new cylinder head way before new injectors.
OT, but does a MC or ONE need an oil catch can?
No, they dont fit on the electrical harness. The plugs are totally different, so... no way !
