Suspension Help! Koni rear strut install issue
Old Sep 20, 2008 | 02:21 PM
minifox2's Avatar
minifox2
I am in the middle of installing my Koni yellows - fronts are done, but I have a major roadblock with the rears. I know that I have to enlarge the holes in the spring seat and the large washer to clear the larger spindle of the Koni - already done. But there is also a 3cm long metal sleeve that keeps one of the bushings from compressing. In reading other posts, it sounds like Koni provides the a replacement sleeve with the larger ID, but I got the Konis used and they didn't come with the larger sleeve. Do I have that correct? If so, then I guess I'll have to drill out the one I have or machine a new one.
Old Sep 20, 2008 | 06:44 PM
minifox2's Avatar
minifox2
No more roadblock - I managed to drill the sleeves out with a hand drill - the steel wasn't as hard as I feared it might be. The car is all back together now - Koni yellows, TSX springs, IE camber plates.
Old Sep 21, 2008 | 10:10 AM
AliceCooperWA's Avatar
AliceCooperWA
Are those IE fixed plates? How do you like the change? That's the set up I'm going for.
Old Sep 23, 2008 | 09:16 AM
minifox2's Avatar
minifox2
They're the adjustable plates. My original plan was to use the IE fixed plates, but Jeff at TSW offered me a deal on a set of used adjustable plates that I couldn't refuse!
Old Sep 23, 2008 | 10:26 AM
spdfreak's Avatar
spdfreak
You've got the same suspension set-up I've got...you're going to love it!
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
squawSkiBum
Oct 2, 2015 09:21 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
