R56 Wierd rattling noise comming from the BOOT!!!!
Old Sep 2, 2008 | 02:26 PM
mnimule's Avatar
mnimule
I have a MCS less than 1 month old and there is rattling noise comming from the rear of the car when i go over small bumps have a wierd rattling coming from the rear of the car
Went to the back tightend everythign including the rubber boot stoppers but still nothing i am so freaking annoyed i just want to drive this car off of a cliff!!!
Old Sep 2, 2008 | 04:57 PM
Joey D's Avatar
Joey D
I had the same thing, turned out to be the number plate. I just got some foam/rubber weather stripping from the local Home Depot and put a small strip of it on the plate. No more rattle. Hope that helps.
Old Sep 2, 2008 | 05:03 PM
sir5150's Avatar
sir5150
you may look under the back. there is a tin heat sheild above the muffler that tends to rattle just a slight tweek keeps it from rattling on the bottom of the car.
Old Sep 2, 2008 | 05:21 PM
mnimule's Avatar
mnimule
thanks ill check that!!!
Old Sep 2, 2008 | 07:59 PM
mnimule's Avatar
mnimule
nope still ratteling think ima take it to the dealer tommorow!!!
Old Sep 2, 2008 | 08:06 PM
BMBULBE's Avatar
BMBULBE
Make sure that the seat belt buckle is not rattling against the door frame when unbuckled and free. That really will make a loud rattle.
Old Sep 2, 2008 | 08:18 PM
Spice Orange JCW's Avatar
Spice Orange JCW
I had a rattle back there that was driving me nuts. It turned out it was the boot cover(if that is what it is called.) The part that does not let you see the contents in the boot. It was not pushed all the way in. Somehow the one side was not clicked all the way in.
Old Sep 3, 2008 | 04:32 AM
1chaos52's Avatar
1chaos52
I had the same thing and it would not go away no matter how much I adjusted the boot stopper plugs. I tried the electrical tape around the loop where the boot latches trick, and have been rattle free for a while now. I am going to have to replace the tape soon as it is starting to come back, but it fixed it for a good 7-8 months.
I would suggest trying this to see if this is the problem, and if it is, maybe look for some alternative way to fix it or just do the electrical tape thing.
Old Sep 3, 2008 | 10:28 AM
mslatter's Avatar
mslatter
I had the rattle, too, and something that sounded like a muffled "met me moutta mere" over and over. It went away after about a week.
For other ideas, check my earlier thread titled, "funny smell coming from boot."
Old Sep 3, 2008 | 10:44 AM
corcoranwtnet's Avatar
corcoranwtnet
MSLATTER:
You might try some foot powder...
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
TREX
Nov 2, 2019 07:31 PM
iclancy82
Aug 11, 2015 09:35 AM
pocketmaster
Aug 11, 2015 07:36 AM
nismo4life
Aug 5, 2015 08:31 AM
