Navigation & Audio Can the OEM AUX cable accept Line Level input
Old Jul 25, 2008 | 09:42 PM
jrprich's Avatar
jrprich
Can the OEM AUX cable accept Line Level input like you would get out of the docking connector of an iPod ?
Or do we need to use only speaker/headphone level outputs to the OEM AUX input ?
Old Jul 25, 2008 | 09:45 PM
Rich.Wolfson's Avatar
Rich.Wolfson
A cable that connects to my dock connector with a 3.5 stereo jack on the other end plugged into Artoo's Aux input works great and sounds a bit better than the headphone out from the iPod. The only problem with that is that I can't charge it at the same time. For that I am thinking a DICE is in my future.
The bottom line answer to your question is Yes. No problem.
Rich
Old Jul 25, 2008 | 09:56 PM
jrprich's Avatar
jrprich
Rich
Sure you can, just use the 3.5 stereo hack to RCA afdapter cable and this cable
http://www.amazon.com/Direct-Audio-I...7048112&sr=1-1
Old Jul 25, 2008 | 10:35 PM
rkw's Avatar
rkw
The OEM AUX is a line level input, and gets better sound out of the ipod dock connector than from the headphone jack. However, most people simply connect it to the headphone jack because they are familiar with standard stereo cables and might not even know about the line level in the dock connector or that cables exist for it.
There are iPod dock cables directly with 3.5mm stereo plug. The retractable ones are very convenient.
http://www.amazon.com/Cable-Ipod-3-5...7049252&sr=1-3
http://www.amazon.com/Logic3-iPod-3-...ref=pd_sbs_e_1
http://www.amazon.com/inspiretech-3-...ref=pd_sbs_e_2
Old Jul 30, 2008 | 01:42 PM
heyitzsushiboi's Avatar
heyitzsushiboi
quick question: i just installed my aux cable but can only hear from the left speaker; the right one doesn't work with aux? the radio and cd functions have all speakers working, just the aux isn't working. any suggestions?
Old Jul 30, 2008 | 03:03 PM
jrprich's Avatar
jrprich
SO either the right cable in the AUX harness is broken or the plug is not aligned, or the cable from the AUX to your iPod is bad
Old Jul 30, 2008 | 03:13 PM
rkw's Avatar
rkw
A mono cable would produce that symptom. Make sure you are using a stereo cable.
Mono: Stereo:
Otherwise, you might have a bad right side connection somewhere in the path between your player and the headunit. Unplug/replug all the connectors or try a different cable.
Old Jul 30, 2008 | 10:41 PM
heyitzsushiboi
Mono: Stereo:
i have this cable from target:
it looks like it's stereo; i guess i have a bad aux line? time to exchange it i guess. thanks guys and sorry for the temporary thread hijack.
W0TM8
Dec 19, 2019 07:50 AM
theblackfalcon
Oct 11, 2015 09:49 AM
blackie
Oct 2, 2015 07:41 PM
FLYM1N1
Aug 16, 2015 01:15 PM
