EBC Greenstuffs and brake wear sensors?
Old Aug 26, 2003 | 12:35 AM
Ryanide's Avatar
Ryanide
I read on another post that
Apparently, starting in the spring of '03 production, MINI started putting brake wear sensors in the LF and RR pads. None of the backing plates that he's seen are perfect for this style sensor. He guesses that the brake manufacturers will change their backing plates eventually.
Anyone know if the Greenstuffs will accomidate the wear sensors? Or how to adjust for them?
Thanks,
Ryan
Old Aug 26, 2003 | 07:39 AM
Alex@tirerack's Avatar
Alex@tirerack
>>Thanks,
>>Ryan
Typically EBC will not accomodate the use of OE wear sensors on most applications.
Alex
Old Aug 26, 2003 | 07:44 AM
Bisch's Avatar
Bisch
Could this be setting off the abs and DSC warning lights?
Old Aug 26, 2003 | 08:00 AM
Ryanide's Avatar
Ryanide
Bisch, are you having a problem with the sensors?
Anyone else experienced similar issues?
Old Aug 26, 2003 | 08:06 AM
Bisch's Avatar
Bisch
A friend of mine just installed h&r springs, ebc greenstuff pads. The ABS light, flat tire, and DSC lights are all on. The run flat light won't even reset...
His car is an '02...MCS
Old Aug 26, 2003 | 12:47 PM
MSFITOY's Avatar
MSFITOY
Just ordered my redstuff today from Helix. Eric told me that the connectors would not fit properly to the current back plates. He just tapes up his harness against the suspension so it would be non functional. The new proper backing plates won't come into line for another 6 month
Old Aug 26, 2003 | 12:56 PM
MiniCD's Avatar
MiniCD
Sounds like one of the ABS sensors did not get reconnected, or was damaged when the work was done. ABS, flat tire and DSC all work off those sensors.
Old Aug 26, 2003 | 11:36 PM
Ryanide's Avatar
Ryanide
I sent an inquiry to the guys over at EBC and their reponse was:
The rear pad ( 1 only) has a hole at the top for the push in wear indicator.
So everything should be fine.
I get my pads on friday from Outmotoring.com. Will post my findings soon after.
Old Sep 3, 2003 | 01:18 AM
Ryanide's Avatar
Ryanide
WRONG! The rear pads do not have a cutout for the electronic sensor that MINI started putting on sometime mid 2003. The company said they were unaware of the change and would be looking into it. Meanwhile, they suggested not using it and just visually checking the wear after about 6 months.
Old Sep 3, 2003 | 08:41 AM
apexer's Avatar
apexer
Its hard to tell from the picture but, it appears that with very little effort you could cut out the required slot for the sensor. Either a die grinder or mill it out if you wanted to take to machine shop. Use the OEM pad as a pattern. Any other ideas?
Toolman
Jan 20, 2016 06:50 AM
thebordella
Aug 31, 2015 01:37 PM
Aug 25, 2015 09:18 AM
jpgwinn24
Tires, Wheels, & Brakes
Aug 23, 2015 02:53 PM
jpgwinn24
R55 :: Clubman Talk (2008+)
Aug 20, 2015 06:57 PM
