Replaced run flats with UHP now pull to right when accelerating
Old Jun 25, 2008 | 05:30 PM
ivan308's Avatar
ivan308
I just replaced my Dunlop Run Flats on my R56 with 215/45/17 General Exclaim UHP tires. I like the ride and they balanced well however now whenever I accelerate hard I feel a pull to the right and then when I let off the accellerator there is a pull to the left. (I did not notice this pull with the Dunlops). The car tracks staright under constant velocity even with no hands on the wheel so I do not think it is an allignment issue.
Is the torque steer more pronounced with the Exclaims due to the softer side wall. I have checked the tire pressure and it is the same all round. It was initally 35psi and I just recently increased it to 40psi.
Any thoughts or comments would be appreciated.
Old Jun 25, 2008 | 08:27 PM
rkw's Avatar
rkw
Sometimes there is enough variation in individual tires to make a difference in traction. Try rotating your tires and see if there is any change. Because the Exclaim UHP is unidirectional, you'd do a front-rear swap. I'd start with swapping just on the right side and see what happens.
Old Jun 25, 2008 | 08:37 PM
loislane's Avatar
loislane
ivan308, I have those same tires on my 07 MCSC and I have not noticed any pull at all. Have you taken it back to where they were installed? Are they all the "same" tire and are they on the car correctly, I mean rotating in the right rotation direction? Good luck on getting this resolved. I hope it all works out.
silence2-38554
98
Sep 21, 2016 02:52 PM
sabjcw
Aug 14, 2015 07:40 AM
xpunisherx
Aug 10, 2015 10:50 PM
Lt. Dan
Aug 10, 2015 08:23 AM
