R55 HD Radio
Old Jun 23, 2008 | 11:05 AM
jlong21's Avatar
jlong21
HD Radio
I am trying to spec a Clubman and I would appreciate any opinions out there on the HD radio option (whether in your Mini or not). I do not plan to to upgrade the stereo in the future.
Thanks,
Jim
Old Jun 23, 2008 | 03:07 PM
howie289's Avatar
howie289
You should ask this question in the 2ndGen/Nav&Audio discussion. I'd like to read the comments about HD (I'll be making the same decision soon). $500 is a bit steep but if you want it nicely integrated into the radio, there's no other choice. The answer also depends on what radio stations are transmitting HD where you'll be motoring. You can google "HD radio" to find a listing of HD stations in every city.
Old Jun 23, 2008 | 03:34 PM
Guest's Avatar
Guest
I've retrofitted HD radio in my R53. It's nice to have, but unless the station you're listening to has high output, or you're close, you don't benefit from it that much.
I find the switch from FM to HDFM annoying too. Constantly switches back and forth if you're in an area with sketchy radio reception.
I'd order it as an option if it were my car, but then I just like knowing I have something, even if I never use it.
IMO an iPod is infinitely more valuable if you're trying to save money. I could count the number of times I've used the radio in my car on one hand. I listen mostly to my iPod, and occasionally XM. I don't even have an antenna!
Just food for thought.
Old Jun 23, 2008 | 05:14 PM
nicknbecka's Avatar
nicknbecka
Personally I love the factory HD radio- there's definitely a noticeable difference. It's a big enough difference that it is annoying when the signal drops from HD to FM and back, but for me it doesn't tend to cycle back and forth that much.
Having lots of HD compatible stations nearby helps make the steep price a little easier to swallow, and the piggybacked HD2 stations are pretty nice too. Here they tend to be broadcasts of sister stations (one local NPR affiliate rebroadcasts BBC for example, another adult rock station rebroadcasts a cross-country blues station) or commercial-less deeper tracks that don't normally see radio play.
Old Jun 23, 2008 | 05:16 PM
DragonWagon's Avatar
DragonWagon
...didn't consider a HD/Sirius/XMS. $1k! Crackheads!
I change the channel or toss in my own beats!
Gawd forbid, we talk to a passenger.
Good luck.
Old Jun 23, 2008 | 05:26 PM
cooper8168's Avatar
cooper8168
What rustyboy said...
Old Jun 23, 2008 | 09:52 PM
ftttuhzbmcs's Avatar
ftttuhzbmcs
I like mine.....but, I wish you could turn it on/off. Our local country station has a delay between their FM and HD broadcasts which drives you crazy after a while as it switches back and forth. Also, some stations don't know how to tune their HD transmission but when they are correctly dialed in, it sounds great. I want all of my vehicles to have it now.
Old Jun 23, 2008 | 10:23 PM
nicknbecka's Avatar
nicknbecka
You can turn it off if you want, at least with the Nav system:
Switching Digital Radio Reception On/Off
Onboard monitor, for operating principle refer to page 16.
  1. Press the Home button
  2. Move the Mini joystick to highlight "Setup" and press the Mini joystick
  3. Select "Settings"
  4. Select "Audio"
  5. Change to the topmost field. Select "HD Radio"
  6. Select "Off"
I don't know if there's an equivalent setting without the Nav. Maybe not?
Old Jun 24, 2008 | 03:16 PM
ftttuhzbmcs
Thanks for the info. I don't have NAV but since you can turn it off in NAV, then there may be a way for non NAV>
Old Jun 29, 2008 | 08:00 PM
Mantid's Avatar
Mantid
I don't have HD and know little about it, but Googled it after reading this thread. Those still in the decision stage may wish to browse through the blog at hdradiofarce.blogspot.com/ I can't vouch for anything about this site.
Old Jul 1, 2008 | 06:43 AM
hoonu's Avatar
hoonu
I found this site pretty compelling, and it sealed the deal for me to not pony up for HDRadio. I was suspicious when I checked out the channel listing and saw how many of the participating stations were ClearChannel stations, but the rest of the info there put it to rest.
bahman
Feb 14, 2016 10:29 AM
pglgp1292
Oct 5, 2015 06:47 PM
ahorvath
Oct 3, 2015 01:13 AM
simo711
Oct 1, 2015 05:36 AM
