Electrical Any consensus on stubby antenna vendor?
Old Jun 12, 2008 | 04:22 PM
Eric (Plug Guy)'s Avatar
Eric (Plug Guy)
Noticed a number of stubbies are available, are they any different from one to another vendor?
Any loss of signal?
Old Jun 12, 2008 | 04:32 PM
speedmini's Avatar
speedmini
I had an Alta stubby antenna and had no problems with the signal. It was even broken off and I had no issues with the signal. I know thats extreme but from my experience you shouldnt have any issues. Good luck.
Old Jun 12, 2008 | 06:37 PM
OldRick's Avatar
OldRick
The stubbies will all reduce the FM signal that comes in thru the rooftop antenna - sorry folks, but physics cannot be denied.
There is no consensus as to whether that matters, as your location and choice of stations makes much more difference than the rooftop antenna.
Stubbies will receive fewer stations in fringe areas, and often give worse reception on those it does receive.
Old Jun 12, 2008 | 06:56 PM
digi0123's Avatar
digi0123
Been running a stubby for 5 years on my other car, no difference in signal between the old antenna and the new...swear on a stack.
Old Jun 19, 2008 | 04:41 AM
dalmightyone's Avatar
dalmightyone
I have to agree here. The antenna's do cause you to lose signal. I tried the 4" and 2". Living inbetween Milwaukee and Chicago, you can definitely see the loss in signal. Before I could pull radio stations from each city, and now they fade out and are weaker. I estimate it reduces your range by about 10 miles over the standard antenna.
Old Jun 20, 2008 | 10:51 AM
LONO's Avatar
LONO
I have 2" from craven speed. Looks good and I can hear no difference in reception even though I understand that physics do not lie. I have HD radio and everything sounds great with 2".
Old Jun 20, 2008 | 11:36 PM
Satsloader's Avatar
Satsloader
A difference, yes. Noticeable? Depends.. I notice that while driving through a shallow tunnel approx 75 yards long, a few local FM stations get some fuzz in the tunnel with the Craven 4 inch I have on now. The factory antenna didn't get fuzz in that tunnel on the same stations. I'm quite amazed just how well the stub does work though, and I tend not to listen to weak FM stations anyway regardless of my antenna. AM is pretty grainy in my area with both antennas due to transmitter locations/distances ( most AM is/are bay area stations like KGO ).
Long story made short, I think most people would be very happy with the performance of a 4" stub. I haven't tried the 2", can't comment.
Bill in P.G.
Old Jun 21, 2008 | 03:47 AM
Xbass's Avatar
Xbass
I have the 4" Craven also - and it works fine for my use.
Old Jun 22, 2008 | 03:45 PM
Ryephile's Avatar
Ryephile
What's FM? For years I've run a chopped-down OEM antenna. Just take a bandsaw to the mast at the top of the rubber section, it's fiberglass with a few strands of wire spiraling up it [in addition to the aero spiral wire]. Viola! You have a $0 shorty antenna.
Don't forget the car has a diversity antenna setup, meaning it has TWO antennas; one on the "hood", and one as part of the boot window.
Old Jul 9, 2008 | 05:46 PM
SPF ZERO's Avatar
SPF ZERO
Moss MINI Antenna
I found a great antenna at Moss MINI. Some may like the Alta, if you're trying to have it disappear totally, but I think this one really looks great! It comes with a couple of different extensions (the black piece) to make it long or short, and two different screw threads.
pglgp1292
Oct 5, 2015 06:47 PM
GAT
Oct 4, 2015 07:27 PM
vetsvette
Oct 2, 2015 07:09 PM
simo711
Oct 1, 2015 05:36 AM
David.R53
Sep 13, 2015 03:44 PM
