R50/53 Clutch being weird....??
Old Jun 5, 2008 | 09:20 AM
hexproject's Avatar
hexproject
i have about 18000 miles on my car..
clutch is weird lately...
when do you usually have to replace your clutch?
part of free maintenance program?
Old Jun 5, 2008 | 09:22 AM
lawmann's Avatar
lawmann
Coordinator :: Middle Georgia MINIs
Can you define "weird"? Without specifics it is hard to give you a good answer.
Old Jun 5, 2008 | 09:38 AM
hexproject's Avatar
hexproject
the clutch use to engage more easily when shifting into gear....
now it has a hard time trying to slot in..
still will go in.. but i have to use more force to shift it into gear...
It's not slipping out of gear.. but just harder to engage into gear when compared to new...
not as smooth as before..
Old Jun 5, 2008 | 10:39 AM
Speed Racer's Avatar
Speed Racer
covered under warranty? Good luck with that one. I've been fighting with the dealer for several thousand miles on mine. First was the weirdness and then the squeal like a throw out bearing going out. Now they are telling me, as is common with most of these threads, that normal wear and tear is not covered under the warranty. What a load of crap! I can't believe for a second that I could trash a clutch within 30,000 miles. If it was a honda, they would stand behind it I'm sure. Oh well, bottom line is that I still really enjoy the car.
Old Jun 5, 2008 | 10:59 AM
hexproject's Avatar
hexproject
well, the warranty is also weird.. since brakes are normal wear and tear and it's covered.... but not clutch?
maybe it's me.. i am sucking it up..
Old Jun 5, 2008 | 11:01 AM
Sixspeed-J's Avatar
Sixspeed-J
Are you sure its not the Transmission? The clutch wouldn't have anything to do with the gear being hard to engage.
Old Jun 5, 2008 | 12:26 PM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
Unless the clutch wasn't fully disengaged and the clutch plate was still in contact with the flywheel. Then it would make it more difficult to get in and out of gear.
Old Jun 5, 2008 | 01:06 PM
sequence's Avatar
sequence
Um, we have soooooo many clutch threads, you should do a search first.
drrigg
May 27, 2022 03:31 AM
eliseo1981
Nov 2, 2015 11:24 AM
unxpectederror
Oct 22, 2015 12:16 PM
Oct 1, 2015 12:13 PM
Sep 28, 2015 09:13 AM
