R50/53 Air bag warning light
Old May 25, 2008 | 09:41 PM
Woobn8r's Avatar
Woobn8r
Has come on in my '03 R53...
I don't really want to take it to to the dealer.....then bend over and take it from the dealer.....
Any Ideas of what I can check before I have to find the KY?
Cheers,
S.
Old May 25, 2008 | 10:01 PM
ChocolateAZ's Avatar
ChocolateAZ
I know they did a fix on mine under a TSB. Not sure which one, it might have been a recall.
Old May 25, 2008 | 10:03 PM
Dr Obnxs's Avatar
Dr Obnxs
There's a warranty extension on ONE of the connectors
don't remember which one. Sad thing is, even if you fix the fault, you still need the right tool to clear the light. It's a latching light, and will stay on even if the fault is no longer present.
Matt
NikiMae31's Avatar
NikiMae31
i have the same thing happen to my 02 r53..i know that autozone in my area will pull the codes for it for free and then you can decide if you want to take it to a dealer..the airbag is covered under warranty sometimes....if you go to autozone and see whats wrong with it you could call the dealer and see if its covered under warranty..if not then have a local place work on it
Old May 26, 2008 | 01:50 PM
Woobn8r's Avatar
Woobn8r
Unfortunately we don't have "Autozone" in my part of Canada...
Old May 27, 2008 | 02:47 PM
Dr Obnxs's Avatar
Dr Obnxs
There are codes and there are codes...
airbag codes are NOT the standard OBD-II codes, and not many scanners can get them.
Matt
Old May 27, 2008 | 04:54 PM
totamdu's Avatar
totamdu
I think this is a common-ish problem. I know I've got it now. I do remember reading they extended the warranty to fix the light for 10 years. call up the dealer I guess.
Old May 31, 2008 | 11:41 PM
Mrono's Avatar
Mrono
my '03 MCS has the airbag light on, they reset it at the dealership and it came back on in the testdrive. they said that they know that the driverside is working but not sure about the passengerside (how they know this is beyond me). it's an electrical problem they said, aparently pretty common
Old Jun 1, 2008 | 06:06 PM
Dr Obnxs's Avatar
Dr Obnxs
Who knows?
The scanner knows. It reports an open, short or whatever for whichever leg of the circuitry is not working right. They ought to be able to say with certainty what connection is flakey...
Matt
Old Jun 2, 2008 | 07:52 AM
Ancient Mariner's Avatar
Ancient Mariner
Gen 1 Mini's had a problem with the wiring/connector under the seat being too short. Sliding the seat to the extreme pulled on the connector. There was a TSB out on it's replacement, I believe. Someone correct me if I'm wrong on that TSB.
Old Jun 2, 2008 | 07:58 AM
dvesh's Avatar
dvesh
I had this same problem. The TSB was for Mini US only. I took it all the way up to Mini Canada and they didn't give two hoots about it. I don't remember how much i paid but they basically replaced the wiring harness under the passenger seat. And that seems to be the common issue too. As someone said, the original wiring was too short and caused a problem.
I'll check to night to see exactly how much it cost me!
Old Aug 13, 2008 | 01:41 PM
Woobn8r's Avatar
Woobn8r
Update**
Turns out the sensor in the front bumper was not attached correctly when the JCW bumper went on...
Old Aug 16, 2008 | 08:57 AM
mnimule's Avatar
mnimule
Originally Posted by Woobn8r
Update**
please explain this, I think this is happeneing to my MCS as we speak!!!! my overhead light sensor just when on last night after I installed my JCW body kit!!!! and the auto windows are also acting up as well!!!
Old Aug 17, 2008 | 08:14 AM
Woobn8r's Avatar
Woobn8r
There is a sensor in your front bumper for the Air bag deployment system.
It must be secured...if it comes loose (and dangles)the sensor cannoit work properly and throws a code....you must re attach the sensor correctly and have your codes cleared.
You are on your own for the window issue....
Cheers,
S.
Old Aug 18, 2008 | 09:22 PM
mnimule's Avatar
mnimule
kool thanks for the heads up so what should i tell my body shop? were should they start looking?
Old Aug 19, 2008 | 10:21 AM
Woobn8r's Avatar
Woobn8r
Once you take the bumper cover off it's pretty evident....
A sensor hanging from a wire! It needs to back in it's clip...and I would tie strap (zip strap) it just to make sure it stays put.
bneer
Jul 15, 2019 04:41 PM
one73ronin
Aug 19, 2015 12:36 PM
JamJam43087
Aug 16, 2015 02:02 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
