Suspension Ireland Engineering Rear Sway Bar
Has anyone used this bar or heard about it..It seems like a really good deal if it works properly, but I havent heard about it or seen it so Im not sure..So if anyone has any experience with it please chime in with your opinion
http://autoxcooper.com/ie_suspension.html
We actually prefer the Hotchkis rear swaybars. They are super hight quality, light weight, and have greasable mounts.
Just my 2 cents.
Just my 2 cents.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
I had the IE rear sway. Didn't have any problems with it, but it was noisier that stock because of the new endlinks.
It is equivalent to a 19mm solid bar. I changed mine out after a year to a 22mm with TSW endlinks.
I have the IE rear bar. It is the 19mm hollow bar that is equivalent to a 22mm solid bar. It made noise when I first installed it, but I fixed the noise issue with some fuel hose.
The install of the rear bar is fairly straightforward. It will take you about an hour if you are mechanially inclined, about double or triple that if not.
I have had it on my '03 for about 3 years and would not trade it for anything.
Good Luck,
Mike
Good Luck,
Mike
Just get an Hsport bar, you won't have to worry about noise. You only need adjustable rear endlinks if your going to corner weight the car.
OK, I moved the end links forward on the bar and made sure all was tightened to factory specs. I still have the same thumping noise I've had since I first installed the bar over a year ago. Any suggestions, other than buying a new bar? This is on my '02 Cooper with a July '02 build date.
The IE Sway bar is a great value, but it's got to be installed and adjusted just right to reduce the noise issues. I have a few Chicago customers running them without issue. Feel free to call me for tips, it's just easier then posting.
yeah they changed the design a lil while ago. I was running the same ones from 2006 that rattled like crazy. I emailed them and they said they had a newer version so i bought them and put them in the same spot that the old ones were in. I have only driven about 10 miles on them, so im not sure how long they will stay quiet
R50/53 Guidance on selling a 2005 S
Toolman
Jan 20, 2016 06:50 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
