R56 Opening the bonnet from the FOB
Old May 6, 2008 | 09:57 AM
postlapsaria's Avatar
postlapsaria
EDIT: By bonnet, I meant boot!!
How is this accomplished? I can't figure it out...
I have the alarm system, so I know if I hold it for 2 seconds the alarm goes off. Other than that, I got it to unlock once (not sure how).
How exactly does it unlock? Should your doors be locked or unlocked? And is there a way to get it to open all the way, or does it just pop open a little for you?
Thanks for any help!
Last edited by postlapsaria; May 6, 2008 at 11:30 AM. Reason: EDIT: By bonnet, I of course meant boot!!!
Old May 6, 2008 | 10:31 AM
poolemac's Avatar
poolemac
the bonnet? (hood?) Can't open it with the FOB to my knowledge.
Old May 6, 2008 | 10:35 AM
RJKimbell's Avatar
RJKimbell
Not the Bonnet, but the "Boot" can be opened with the Comfort Access FOB. There is a separate button on the FOB for the Boot. You can also press the Button on the Door Handle and that will unlock all doors including the Boot.
Old May 6, 2008 | 10:42 AM
mellowmcs's Avatar
mellowmcs
Don't hold it for 2seconds. It takes about 1 second maybe a tad more to pop the hatch. It's a fine balance between opening the hatch or setting off the alarm. I set it off about 4 times demonstrating that "feature" to my friends.
Old May 6, 2008 | 11:17 AM
caulyne's Avatar
caulyne
It pops, it doesn't open all the way up. (At least mine doesn't. It's not like on our Jeep where when you hit the button, the rear window swings itself up and open.)
Old May 6, 2008 | 11:20 AM
Scavenger's Avatar
Scavenger
American --> British translation:
Hood -> Bonnet
Roof -> Hood
Trunk -> Boot
Old May 6, 2008 | 11:29 AM
postlapsaria
Wow, I know the boot is the trunk.......I guess I'm brain dead from finals week Anyway, thanks for the help!
Old May 6, 2008 | 12:53 PM
wdavidhicks's Avatar
wdavidhicks
A very fine balance...
What I'd like to figure out is how to open the boot with the fob in the ignition and the engine running. I've been shutting the engine off and pulling the fob if I forget something I wanted out of the boot.
Old May 6, 2008 | 01:23 PM
caulyne's Avatar
caulyne
Hit the unlock button a couple times on the toggle switches, open door, walk to back of car, open boot.
Old May 6, 2008 | 02:18 PM
mellowmcs's Avatar
mellowmcs
as long as the door is unlocked, you can use the button that is on the rear hatch. you might need to feel around for it.
Old May 6, 2008 | 02:30 PM
Krafty04's Avatar
Krafty04
Hood -> Bonnet
Roof -> Hood
Trunk -> Boot
Shew, good thing were not in England.
Old May 6, 2008 | 11:11 PM
wdavidhicks
Duh.
I figured it out today. I need to flip the lock toggle on the lower switch row and then I can open the boot with the engine running.
Old May 7, 2008 | 01:59 AM
rippymcs's Avatar
rippymcs
The boot release mechanism is quite finicky; I have to press the button on the fob several times before it would actually unlatch.
Old May 7, 2008 | 05:07 AM
JCR1960's Avatar
JCR1960
Just hold down the boot/hatch release button and wait for the open/pop sound.I was use to the trunk opening right away on my 2006 Mustang GT from the key fob.I had to figure that out when I bought my MCS that there is a slight delay after pressing the button.
Old May 7, 2008 | 04:53 PM
rippymcs's Avatar
rippymcs
I have the factory alarm so I can't hold the button down too long or it will trigger the alarm.
Old May 7, 2008 | 06:11 PM
JCR1960's Avatar
JCR1960
Gotcha.
The factory alarm isn't listed in your sig which would have been a different reply then.
joedotmac
Oct 23, 2015 11:32 AM
kevins
Sep 23, 2015 01:46 PM
kevins
Sep 23, 2015 12:12 PM
WillShootPhotos
Sep 14, 2015 07:50 AM
HogWldFLTR
Sep 8, 2015 05:25 AM
