R50/53 SNAP! When closing full open sunroof
Old May 4, 2008 | 12:13 PM
gswallow's Avatar
gswallow
Have had my 04 MCS since Christmas and love it. Have the sunroof in tilt most times. Today had it fully opened. Closed fine for a couple of stops. Did just fine yesterday (Sat 08053) too. However, get home today and closing the sunroof makes a load snap, like a rock hit the glass, noise. Checked out from fully open to close and there's an arm that comes up on both sides of the sunroof. I suppose they guide the sunroof into place. Passenger side arm lifts and snags for a moment on the corner of the frame around the glass. Closes ok, but the noise is scary , From a tilt or just a little farther than tilt no snag, but from a fully open position to close makes ya feel like you're under attack. Anyone got an idea of the (better be easy) adjustment?
Old May 5, 2008 | 05:23 AM
slickfast's Avatar
slickfast
If youre on good terms with your dealer they might be able to have a no cost tweak that they could do. Never hurts to give them a call and see if theyve heard of it. Good luck!
Old May 5, 2008 | 06:32 AM
Xymox's Avatar
Xymox
Sounds to me like your guides are dirty and need lubricated. See bottom of this post: https://www.northamericanmotoring.co...ad.php?t=73456
Old May 10, 2008 | 07:11 AM
andrewholmes's Avatar
andrewholmes
same deal here
i had the same problems about a month ago. sunroof worked and SOUNDED fine every time then one day..SNAP!! you are right thought...scares the heck outta ya when you first hear it. all i did was open the roof, use some glass cleaner and a few q-tips to clean all the tracks...then lube the heck out of it with white grease. made a bit of a mess on the outside of the roof but after opening and closing it a few dozen times the sound went away and a power wash cures the goopy mess .
trust me here...if that ends up being the biggest problem with your MC...you are one lucky dude
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
cub4bearindiana
Jun 30, 2016 06:11 AM
actualsize37
Sep 1, 2015 06:43 AM
SheldonCooperS
Aug 25, 2015 11:57 AM
