Navigation & Audio Voice/phone command problem. Help.
Old May 2, 2008 | 04:09 AM
MTRHED's Avatar
MTRHED
I searched and did not find any results.
The manual states "store name" to load the name/number. The system responds back "star 9" ????
I push the voice button "enter name" "please say the name" "%#&@"/repeat "please say the number" repeats number. From here is where it stops working. I say store name...nothing. What am I doing wrong? Thanks for any input.
Old May 2, 2008 | 05:56 AM
geekswrath's Avatar
geekswrath
This has been discussed before. There is a misprint in the manual. Instead of store you are suppsoed to say save. I'm not 100% on this though as it's been a few months since I've done it.
Best thing to do is to say help and the car will list the number of available commands.
It is a bit frustrating.
Old May 2, 2008 | 06:16 AM
MTRHED's Avatar
MTRHED
I tried that. It says something like "pound 9"????
Thanks though. I will probably have to take a trip to the dealer.
I just got one in using "save" then it started cutting me off in the middle of loading the info on the next one. It did this 5 times in a row and I cut IT off.
Old May 2, 2008 | 03:45 PM
Otra's Avatar
Otra
Since I just attempted this and kept hearing something like "phone book empty" after several attempts, I decided it was getting cold and late. Came in saw this thread and did a search finding https://www.northamericanmotoring.co...voice+commands and from there I went to https://www.northamericanmotoring.co...d.php?t=113353 where in the first post we find:
Originally Posted by BigFatGuyinaMiniS
So...I was one of the folks who had a BT ready '07 MCS with a phone that had BT. Everything seemed to work, except voice dial. I read and read the manual, threads, etc. and I could not get it to work. Then I combined a few different options and here is the solution.
1) PUSH Voice Dial button on wheel...
2) "BEEP"
YOU - "SAVE Name" (you must say SAVE, not Store like the manual says to do)
3) MR BT - - "Say the name "
You
- -"......." (what ever name you want to save)
4) MR BT - - "Say the Name Again"
YOU - - "........" (again, say the name)
5) MR BT - - "Say the number"
YOU - - "###-###-####"
6) MR BT - - repeats "###-###-####"
MR BT - - "Continue"
YOU - - "SAVE"
Hope this helps!!!
Tomorrow I will try again using "Save Name" and report back - hopefully with good news. Then I will kiss the feet of this fellow.
Old May 5, 2008 | 12:04 PM
davo_florida's Avatar
davo_florida
just did mine yesterday exactly as described above and everything saved properly. thanks!
Old May 5, 2008 | 05:51 PM
Otra's Avatar
Otra
Worked very well with my LGVX5300- BigFatGuyinaMiniS, you're the best! Now, to explain it to my MA.
PelicanParts.com
May 14, 2026 04:59 AM
Keet
Suspension
Aug 30, 2016 03:46 PM
chowpott
Oct 19, 2015 08:37 AM
PelicanParts.com
Accessory Products
Oct 1, 2015 01:23 PM
TifosinDel
Sep 28, 2015 10:45 AM
