Navigation & Audio Another SIRIUS question
Old Apr 23, 2008 | 11:31 AM
joejoe01's Avatar
joejoe01
First of all, I just took delivery on a 2008 Clubman. I did not opt for the factory installed Sirius. We have a Sirius Starmate radio that we are going to mount somewhere in the vehicle.
My question is this. I want to connect power and antenna to the factory pre-wired Sirius connections. What do I need? Does anyone know the specific adapters needed to make the install?
I know this info is probably scattered throughout this forum, but cannot put my finger on it.
Old Apr 23, 2008 | 01:59 PM
daveag98's Avatar
daveag98
To wire direct into the antenna you need a satellite cable pig tale, plugs right into your starmate. Then to do the power use the add a fuse from parts direct. I will see if i can find the thread about the install.
If you have a car audio guy do it, they will have everything on hand.
here is the fuse install
https://www.northamericanmotoring.co...43#post1702343
I can not fine the sat cable thread but you have to unbolt the passenger seat to get to the cable, its under the carpet under the seat. I tried my best to get to it without unbolting the seat but no go.
https://www.northamericanmotoring.co...d.php?t=124616
that was easy
donniedarko
Oct 21, 2015 01:15 PM
PSU 98
Sep 11, 2015 11:20 AM
cinnabun
Sep 11, 2015 05:55 AM
marc0011
Sep 10, 2015 10:04 PM
Robree
Sep 9, 2015 08:43 AM
